Ground for Amp
Old December 9th, 2010, 09:39 AM   #1
zammutog is on a distinguished road
Ground for Amp
Hi Guys,
I have a 2004 Mustang Coupe v6 3.8L. I just installed an infinity amp and 12 inch sub in the trunk. I can't find a good ground for the amp though. I know in the trunk, under the carpet there is a screw hanging down with a nut, which would make a logical choice. Though this does not seem to be working. Any suggestions on where else I could ground it?
Thanks in advance for the help...
Old December 9th, 2010, 09:43 AM   #2
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
Did you clean all the paint from around there?
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old December 9th, 2010, 10:45 AM   #3
AndyG47's Avatar
2002 Mustang V6
Slow
AndyG47 will become famous soon enoughAndyG47 will become famous soon enough
I had mine grounded to one of the bolts that holds the rear seat belt's clicker side in underneath said seat. Make sure to clean a bit of the paint off as SickFox said, you need metal to metal contact.
_
2003 F150 - 5.4L V8 4x4 - 109K hard miles & still going FORD Tough----2002 Mustang 3.8L V6 - Currently undergoing "I'm not 17 anymore" demoding
Originally Posted by OneShotOneKill View Post
this thread has more fail in the first 5 posts than all of the "what exhaust?" threads in the v6 section.
Old December 9th, 2010, 12:06 PM   #4
236Mustang's Avatar
236Mustang will become famous soon enough
_
this...
that is were i put mine when i had my subs
1995 Turbo V6 Mustang (auto)
Check out my build <----
ET: 14.1@99mph (coupler blowing off/MBC failing )
Built by Iron Horse Motorsports
Old December 9th, 2010, 12:36 PM   #5
01 Slate Stang's Avatar
2001 Mustang
0 - 60 5 minutes
01 Slate Stang is on a distinguished road
that bolt that u described as hanging down i cut mine off and used a grinder to remove the paint from the surface and installed ground wire there. GL
Old December 9th, 2010, 10:22 PM   #6
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
I put my ground on a bolt hanging straight down from the top of the trunk near the stock speakers.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old December 10th, 2010, 12:11 AM   #7
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
The seat belt screw is the best choice of course. You have the most surface area for your ground wire. also it wont come lose easy at all
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old December 10th, 2010, 12:23 AM   #8
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Do you have proper power? Take a test light to the ends of the power and ground wire. Do you have your switched wire hooked up?
271rwhp N/A V6
Suck it.
Threads Similar to: Ground for Amp
To ground effect or not to ground effect...that is the question... timalev 5.0 Mustangs 3 September 13th, 2010 08:15 PM
Ground Up Build brought_pain Classic Mustangs 2 August 11th, 2010 06:14 PM
ground 87gtmustang 5.0 Mustangs 9 January 4th, 2009 02:22 PM
gt ground effects 347tt 5.0 Mustangs 22 March 7th, 2007 01:10 PM
ground effects mustangmaniac 5.0 Mustangs 10 December 4th, 2006 06:52 PM
