791xv & 2004
Old December 10th, 2010, 12:24 AM   #1
xNitr0us's Avatar
2004 Mustang Convertible
xNitr0us is on a distinguished road
791xv & 2004
I have everything installed correctly and I also have the 452D Door trigger module installed on the drivers side trigger (hoping thats how to do it?) anyways I turn the key and push the valet switch 1 time and push it again and hold and its chirps twice I believe? then the LED flashes and when I press a button on my remote (DEI478) it doesnt program, the antenna is plugged in and the brain and remote are communicating im assuming since otherwise it would give the no signal sign and beep as it does when im at work since its out of distance, I have remote start put in (my stang is auto) but no spare key yet so i doubt thats causing this?, the shock sensor has blinked red if that means anything. I dont believe my brain or remote is dead. a shop did install it but I do understand the wiring. every 30 seconds it seems my remote is showing the recieveing signal but my remote shows a full battery and the unlock sign along with vibration mode, also when I unplug the antenna it says no signal and plug it back in it doesnt beep and shows the recieve signal on the remote so its gotta be communicating. I have the door triggers hooked up to the 452D as negative and when i turn the key to on to program my doors auto lock and auto unlock when switched off, I have a proximity sensor waiting to go in (have a vert) BUT WHAT THE HELL IS WRONG!?,
- does auto lock/unlock on key on/off
- shock sensor blinking red?
- does go into programming mode so not locked
- have tried the remove all remotes sequence
im lost as to what is making this thing work and want to give up but to pissed to, any advice? im not really looking to go to a shop or the 1 that installed since they told me bad remote or bad brain but I dont think so and they will just say the same shit again
Threads Similar to: 791xv & 2004
791xv & 2004 mustang convertible xNitr0us V6 Mustangs 3 November 30th, 2010 03:38 AM
