Weird (Starting Questions)
Old December 14th, 2010, 08:48 AM   #1
Needs 2 cylinder bolt on
Mach Stang's Avatar
'03 Mustang V6
It's a six so what do you expect?
Mach Stang is a jewel in the roughMach Stang is a jewel in the roughMach Stang is a jewel in the rough
Ok I know that my battery needs to charge some more considering that the car barely turned over when I went to start it. Currently -3 Degrees out here lol. But any ways, when the car did start after a bout 10 - 13 turns, but then the gauges, all of them, shot up to there max points. Speedo past 120, RPS past 8K, Fuel to F ect... Then they dropped back down to zero. After about a second the the gauges went through the start up procedure like normal. I've never seen this be for, is there a reason?
BTW, My Theft light was flashing a little bit faster than normal before I put the key in.
"you're alive for a reason, DON'T GIVE UP"
Originally Posted by SoMDWhite03GT View Post
Going down to NC for the NASCAR race!
When I seek that kind of entertainment I sit by the the red light near my house and watch all the cars turn left
Old December 14th, 2010, 09:17 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
That typically only happens when you've disconnected/reconnected the battery. I wouldn't worry too much about it, due to the air temps you're experiencing. Basically, your battery is "giving it all it's got" to start the engine at those temps.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 14th, 2010, 09:22 AM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ yep.
You may want to invest in a battery with a higher cca rating for the future; or a block heater.
Old December 14th, 2010, 11:36 AM   #4
Mach Stang's Avatar
'03 Mustang V6
I got one of the best interstate batteries, so I'm hoping its only low on charge. I'll put the charger on when I get home. BTW, whats this block heater you mentioned?
Old December 14th, 2010, 11:55 AM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
ZEROSTART MAGNET-MOUNT ENGINE BLOCK HEATER - JCWhitney
Old December 14th, 2010, 12:01 PM   #6
Mach Stang's Avatar
'03 Mustang V6
Hm, I Might have to look into it. Cause it's just only gonna get colder lol
Threads Similar to: Weird (Starting Questions)
Starting seems weird wildhorse95 94-95 7 December 8th, 2010 03:25 AM
starting the build soon.....questions silverstang 2005 - 2010 8 July 6th, 2009 11:19 PM
AOD questions - weird shifting in/out of OD and shift kits ReverendDexter 5.0 Mustangs 4 July 1st, 2009 11:33 PM
couple quick questions before starting the car tomorrow!! Dolbs4082 99-04 22 May 13th, 2009 05:24 PM
Building a 347 Soon..Questions...So Starting Early Speedstang302 5.0 Mustangs 10 September 25th, 2007 09:53 AM
