Would a valve cover gasket leak affect idle?
Old December 14th, 2010, 06:31 PM   #1
00mustangv6's Avatar
2000 Mustang v6
00mustangv6 is an unknown quantity at this point
I have the valve cover gasket leak and my idle bounces around sometimes, and my gas mileage doesnt seem as good..would this affect it?
Old December 14th, 2010, 10:18 PM   #2
1996 ford mustang
theyanks904 is on a distinguished road
nope sure wont .... but pull the iac off your car and clean it its located on your throttle body probaly will take care of the problem ...and its free to try most the time thats the problem
Old December 14th, 2010, 10:24 PM   #3
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
I'm pretty sure it will affect idle...I don't remember how they are run on stock cars.
But if there is one connected to each valve cover and to the manifold for vacuum, a seal leak will definitely be a vacuum leak.
Twin Turbo
Old December 14th, 2010, 10:29 PM   #4
1996 ford mustang
yea a vacuum leak will cause idle problems but not a oil leak
Old December 14th, 2010, 10:35 PM   #5
9986paulk's Avatar
1999 Mustang V6
what about an oil leak? If there's oil leaking through it and the inside is subject to vacuum, it is also going to be sucking air in.
Twin Turbo
Old December 14th, 2010, 10:45 PM   #6
Dancing Naked In The Rain
mcqueen's Avatar
To clear this up, the inside of the valve cover is subject to vacuum (pull the PCV line off your valve cover and feel the suction). A leak in the valve cover would allow unmetered air to enter into the valve covers and get sucked into the upper intake, blah blah blah (imagine I just explained how air travels through an engine). That air didn't pass through the MAF so the air is unmeter and likely to case problems such as odd idling.
My Hubpages
Hey.. r u really a tranny??
Old December 14th, 2010, 10:55 PM   #7
9986paulk's Avatar
1999 Mustang V6
thank you ^
Twin Turbo
Old December 14th, 2010, 10:57 PM   #8
1996 ford mustang
thanks
Old December 15th, 2010, 07:47 AM   #9
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
+1, don't forget this will eventually cause you to run lean. And I could imagine if you deal with A LOT of dust in your area (I don't know just saying) it could cause a mess of problems. But it depends how big the leak is.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Threads Similar to: Would a valve cover gasket leak affect idle?
need How to on valve cover gasket change plz starin 96-98 5 January 19th, 2010 07:23 PM
changing valve cover gasket wraitherx 4V / SVT 10 September 24th, 2008 10:04 PM
BBK Valve Cover Gasket Hotrodvdog 99-04 20 December 24th, 2007 05:09 PM
changed valve cover gasket caintcatchmyGT 96-98 1 November 4th, 2007 01:32 PM
valve cover gasket terribleonexx88 5.0 Mustangs 5 July 25th, 2007 03:20 PM
