Keyless entry problems
Has anyone else here had problems with the keyless entry i can unlock my car but I can't lock it from my remote. Ive check all the fuses in the car Ive resynced it several times but still wont work. Any ideas on what else to check? If I push the lock button twice the horn honks so its receiving the lock signal Its not the motor in the door because I can lock it from inside the car just fine just not from remote. Any ideas please help. Thanks
Resident badass
Stock or aftermarket?
Mine will occasionally not lock when I hit the lock button. (on the door)
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
Its all stock its the stock ford one. Like i said the interior button is fine thats how i lock it when i get out now. But its the wireless remote like i said it honks the horn when i push it twice but yet u can't hear the click in the computer in the trunk or the doors don't do anything.
Any ideas anyone?
Resident badass
Change the battery. You you have another remote?
I'm Learning Drugs ΔΧ
2000 3.8 Mustang
I was gonna say check your battery, it seems like nothings wrong with the system
Resident badass
The battery in the remote I mean.
That was the first thing i thought so i changed the battery and still same problem everything else works just fine.
The best 2003 Mustang
She's fast.
I think there is a problem with the recieving end on the door itself and although it works it may not be getting the signal through to the door but it sends it to the other components like usual.
You're gonna need to take it to ford and cut off your arm to pay to fix this. But that's just what I believe and since you've tried it all it seems ford is your best option and the only thing else I can think of is check your chips regardless of whether they work for the door or not and make sure everything is plugged in right and pushed in all the way. and one other idea could be a wire somewhere is not hooked in right. but where I don't know. (in the door, keypad, idk sorry) sorry if this is confusing but I thought of things as I was typing =p |
Ive gotten so fed up with it i just fell like...
Lol seriously |
Does anyone have a digram for the keyless module? so maybe i could trace the wires?
2000 GT 'vert
my bet is that it's the remote.. if you don't have a second remote AND key, you are looking at $130'ish to get a second remote programmed (You need two keys to program the remotes).
Yeah but if its the remote why does it (push once does nothing push again and it honks the horn) just like every other one Ive seen first locks driver door second locks all doors.
2000 GT 'vert
awww.. i missed that. that's a tough one.
Thats why i asked for digram so i could trace the wires coming out of the receiver on the car.
Resident badass
Best I got. Everything I have is for 01-02
Thanks ill try that.
00 Mustang Convertible
try to reprogram the remote.. you DON'T need two keys to do that.
cycle the key about 8 times from off to on position, without turning the car on- untill you hear the door locks click.. then press any button on the remote, turn the key to the off position and baM.. you just reprogrammed your remote.. that should fix the prob. |
#19 | |
2000 GT 'vert
I didn't have a remote so I bought one off of ebay and I only have one key. didn't have any problems programing the remote. works perfect.
from my understanding two keys are only needed if you need to program the KEYS ... the fob- remote is a whole different story. |
Threads Similar to: Keyless entry problems
| Keyless Entry | nHuman | 96-98 | 23 | March 5th, 2011 12:37 PM |
| Keyless entry for 96 | war1ock | 96-98 | 5 | March 5th, 2011 12:35 PM |
| Problems with programming keyless remote entry | adrian91gh | 96-98 | 6 | December 27th, 2010 02:25 AM |
| Keyless entry? | mustangmad | 94-95 | 0 | November 14th, 2009 02:17 PM |
| keyless entry | dr.gonzo! | 5.0 Mustangs | 7 | June 20th, 2008 12:11 PM |
