'03 V6
Hanging Idle?
Intermitant problem when I put car in neutral the idles will hanga bit before dropping, or sometimes increase when shifting thru the gears. Anyone know why this would happen or what the potential fix is?
BLACK 6er CLUB |
#2 | |
Finally took it in to get it checked and it turned out I had a bad Throttle air bypass valve assembly. It was causing my car to run rich and ended up screwing up my injector system too. My car smelled like gas as I pulled into the garage. Had I gone much longer it might have been ruined. It was a hefty repair. I'm not saying this is what you have, and I hope it's not. If you check it out early enough, you might not have anything major on the side to deal with also. Hopefully your case is something far simpler. |
Actually, the first thing I would do on yours is disconnect the battery for a few hours and let the computer reset itself. If you have a simple fix, that should take care of your idling issues. If it doesn't, then there's something else.
my car also does that...did you put in a new CAI by any chance...when my car was idling bad the mechanic changed out the MAF and the IAC motor...also said i needed a tune up...try cleaning out your MAF...hopefully that might do the trick
I'm doing it wrong
04 Grand Cherokee
You don't need to disconnect the battery for a couple hours to reset the computer. 15 minutes does the trick.
I had that problem, I would put it in park or neutral and my idle would hang at 1-1.2k rpm's. And would only drop if I put it in gear. I replaced my DPFE sensor and it fixed it. Clean your MAF with MAF cleaner, DONT USE ANYTHING OTHER THAN THAT TO CLEAN IT AND BE VERY CAREFUL. And clean your IAC with Throttle Body cleaner. Should fix your issue. If not let me know.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
'03 V6
Do What???? ok like how do I clean my MAF? please break this down barney style for me. IAC? A little help for a newby.
BLACK 6er CLUB |
'03 V6
ok so tracking with the MAF. just reading thru the haynes manual now on how to pull it so i can clean it...but DPFE sensor?
BLACK 6er CLUB |
'03 V6
ok...found good write ups on this on muscular mustangs . xxx
BLACK 6er CLUB |
2002 Nitrous Injected V6
12's?
tell us how it goes
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
'03 V6
well....still nothing changed
I cleaned the MAF but still seems to be functionng the same.
For example, I will be going up hill and when I hit the top of the hill say around 2nd gear at around 2.3k and start downhill alot of times i will just pop into neutral and coast down hill and the idle will drop to 950ish-1.2K. Only when I come to a complete stop will it settle down to around 700ish. there have been a very few time that when i do that the idle will drop immediately to 700ish but that is the exception. And most of the time something similiar happens when exiting the freeway off ramp from 5th gear around 2 - 2.3 rpm at 70mph i will pop into neutral and coast to the light at the end of the exit ramp it will do the same as described above. is this right? I did read another thread where it talked about this is normal due to some sort of pressureized brake system (?). I havent pulled the IAC yet cause the picture in the manual i have is kinda deceptive and I was looking for a good photo showing specifically where it is located. The write up i saw explaing that it is just pulling to bolts and removing it and spraying it down with the throttle cleaner and then reinstalling. Any comments or suggestions from anyone would be greatly appreciated.
BLACK 6er CLUB |
'03 V6
ok..found the IAC...actually mounted on the 'back' side of the Throttle body (looking from the front of the engine compartment) will clean that tonight and see what happens.
BLACK 6er CLUB |
It is a very common problem on this car. And definately try cleaning the IAC otherwise some have went to an IAC restrictor plate to restrict the airflow at idle to prevent it.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
'03 V6
cleaned the IAC tonight. took for a test ride and throttle response improvement was def noticiable. seemed like the 'return to idle' in neutral was much improved. gona give it a week and do a second cleaning just to see how things go.
Codeman. While I appreciate the restrictor plate idea you and others i have read mention, I dont like the idea of trying to self modify something like that. One, it seems like a hack job, and two, if they wanted it with smaller holes, they would have made it that way, but defently....thanks for the suggestion.
BLACK 6er CLUB |
Threads Similar to: Hanging Idle?
| 2001 Mustang Gt High/Hanging Idle | stangballer | Modular Mustangs | 4 | November 15th, 2010 10:53 PM |
| help hanging idle | rider4life350 | 99-04 | 16 | November 14th, 2010 11:07 AM |
| Hanging Idle | 90Stang | 2005 - 2010 | 2 | November 25th, 2008 11:59 PM |
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| hanging idle | Baneful | 99-04 | 11 | June 27th, 2007 03:41 PM |
