Gah! My clutch pedal started rattling
Old January 7th, 2011, 04:09 PM   #1
2002 Mustang
frodo2975 is on a distinguished road
Over the last couple of weeks, my clutch pedal has starting rattling at low rpms. It sounds like I've got woodpeckers under my dash! If I lightly touch my foot to the pedal, the noise stops immediately and I feel a decent amount of vibration. However, if I press the pedal in an inch or 2, all the vibration in the pedal stops. BTW, I'm driving a 2002 v6 with around 105k miles on it.
Initially, I thought the bushing on the pedal shaft was worn, causing the pedal to move around too much, but when I took it apart, it looked fine. I replaced it anyways, but the noise is still there. Also, The previous owner replaced the clutch about 10k miles ago, so it should still be good. Any of you guys have any ideas what's causing the vibration? Thanks.
Old January 7th, 2011, 05:44 PM   #2
2000 Mustang V6
Chubbs02126 is on a distinguished road
I have the same issue on my car, I was told it has to do with the flywheel being loose. Since I plan on replacing the clutch and flywheel next month I have just been dealing with it. What your doing is the best work around "lightly touch my foot to the pedal, the noise stops immediately "
Old January 7th, 2011, 09:47 PM   #3
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
Its not the flywheel I don't think. I had the same problem and it was my clutch cable. It had slack in it especially when I got my new clutch installed. I replaced the cable and sure enought it was it. Hope this helps
Old January 7th, 2011, 11:45 PM   #4
2002 Mustang
Thanks, I'll try replacing the cable and let you know how it goes.
Old January 8th, 2011, 12:13 AM   #5
ag11hockey's Avatar
1999 Mustang V6
Just a little more input... id just buy the clutch adjust kit from AM for a hundred bucks. Might as well and I think its worth the money
Old January 9th, 2011, 01:46 PM   #6
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Throw out bearing.
Old January 9th, 2011, 04:32 PM   #7
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
^ Its 100% your T.O.B. it happens to almost all cars around 100k miles.
While youre replacing it you might as well do the clutch and resurface your flywheel
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old January 9th, 2011, 05:09 PM   #8
ag11hockey's Avatar
1999 Mustang V6
not always true. but it is a likely cause. when i installed my new clutch it rattled right away and it was the cable
Old January 9th, 2011, 05:10 PM   #9
ag11hockey's Avatar
1999 Mustang V6
Old January 9th, 2011, 05:10 PM   #10
ag11hockey's Avatar
1999 Mustang V6
Old January 9th, 2011, 06:17 PM   #11
Dancing Naked In The Rain
mcqueen's Avatar
Originally Posted by goren813 View Post
Throw out bearing.
I'm going to bet this is the most likely cause. My clutch started rattling just before my TOB started chirping.
My Hubpages
Hey.. r u really a tranny??
Old January 9th, 2011, 06:26 PM   #12
1996 ford mustang
theyanks904 is on a distinguished road
put a TOB in it ..... you should just put a clutch and slave cyl in it ..... depending on mileage ..... if your around 100k i would
Old January 9th, 2011, 07:21 PM   #13
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
TOB mine just went but my clutch was still about 30%. I was impressed. I changed it anyways but ya throw out bearing for sure
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old January 9th, 2011, 07:25 PM   #14
Six Banger's Avatar
2001 - 3.8
true. but when it starts rattling after 100k miles of driving, it is more likely the bearing. a new clutch will rattle if it isnt adjusted right
Old January 9th, 2011, 10:42 PM   #15
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Sounds like a combo of the TOB going kaput, and the pressure plate chattering.
271rwhp N/A V6
Suck it.
Old January 10th, 2011, 12:52 AM   #16
focus0frenzy1 is on a distinguished road
i got 76k on my 04 and i have this same problem
Old January 10th, 2011, 03:34 AM   #17
ag11hockey's Avatar
1999 Mustang V6
sorry about the triple post. the internet was being dumb.
Old January 10th, 2011, 12:10 PM   #18
goren813's Avatar
'00 3.8L & '05 4.6L
What? Cable clutch home slice no slave cylinders involved. And since OP is high mileage and stock components I say TOB. I would say cable is a possible cause as well, however normally a stock cable on stock set up isn't gonna be the first thing to go. These cars are notorious for shitty TOB's.
Old January 10th, 2011, 06:58 PM   #19
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
If you get a new TOB. ONLY get a ford racing heavy duty TOB. I compared it to the one that came with the clutch, and it weighed almost twice as much, but had no play in it what-so-ever. The ram one looked like it would start to go out by the time I took it for its maiden voyage.
This is the one I got.
FR HD TOB
Make sure you grease it well too.
271rwhp N/A V6
Suck it.
Old January 12th, 2011, 03:02 AM   #20
2002 Ford Mustang
Mochomo28 is on a distinguished road
I just had this problem after installing a brand new clutch. The mechanic told me to change the clutch because it was defective. Went and exchanged it, mechanic put it on and it workds fine now.Btw, Flywheel was resurfaced before both times. Also my car is at the 150k mark..
Threads Similar to: Gah! My clutch pedal started rattling
Found out why the Clutch is making a rattling sound Shaun03GT 99-04 37 October 28th, 2010 02:32 AM
New clutch, rattling noise under a load? Shaun03GT 99-04 20 September 13th, 2010 10:40 PM
clutch pedal vibration and excessive clutch chatter mscribellito 99-04 13 August 19th, 2010 04:59 PM
Clutch pedal 91 fox 5.0 Mustangs 2 October 4th, 2009 08:12 PM
clutch pedal.... the real shocker 99-04 36 April 9th, 2008 12:10 AM
