2000 Mustang v6
CAI problems
So i got the v6 CAI from american muscle.
I installed it and now I have a Check Engine lite reflecting off the dash to the windshield starring at me tearing my heart out... sorry if im dramatic. Any way there are two sensors and 1 vac line if i remember correctly. 1) the one sensor is already mouned and simply bolts on if I remember correctly 2) and the other is simply pushed in. i already had the lite cleared one time and after a few hundered miles it came back on. both times the light has come on was during idling for an excessively long time. i forget what the code was but the guy at advanced who cleared it mentioned an 02 sensor then a vacume leak. said he didnt know. there was only one code but i forget what it said. What is the second sensor? I may have broken it while pushing through the rubber grommet because it was really redicuclously hard to get in. |
I'm doing it wrong
04 Grand Cherokee
You plug the hole in on the piece of the CAI piping right before the TB? The GT's have something that goes in there but the V6's don't so we have to plug it up with something. I used a cork.
Forget to plug in your MAF? Or did you damage it in any way? If it is something to do with O2 sensors I am taking a wild guess and assuming your running either rich or lean (lean being the one I am leaning towards.... ) meaning there is un metered air getting in after the MAF which would result in that hole I was talking about not being plugged up..... Our V6's only have one Vac line that goes to the CAI btw. Not 2. Lastly, check to make sure all the rubber rings on the CAI are secure and not leaking at all. I have seen some people install the one that goes from the TB to the CAI wrong and had a bunch of extra air going in.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Resident badass
Make sure everything is sealed off.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
2000 Mustang v6
ahh yes there is a slight whistle so maybe one of the clamps isnt all the way tightened.
demon are you saying that you only had one sensor bacause i have 2 |
2000 Mustang v6
#6 | |
I'm doing it wrong
04 Grand Cherokee
Also the CAI itself does whistle, its the filter sucking in air. Is that pic you referred to your actual car? If so I didn't have a plug that went into that bung right next to the TB... So I can't help you there, I don't even know what it is lol.
2000 Mustang v6
its the intake air temp sensor that i was worried about breaking
also not retarted over here except im havin trouble with the CAI so maybe I am. no that was not my car |
2000 Mustang v6
Ford Mustang Cold Air Intake - Video Installation Instructions at AmericanMuscle.com
u can skip to 2:50 sec if u dont believe your eyes that a sensor goes there. they must have changed it in 2001 |
I'm doing it wrong
04 Grand Cherokee
I know a sensor goes there, I just thought only GT's had it. Apparently pre '01s did too. Not doubting you saying you put a random sensor in there because it fit lol. I just said to plug that hole up because thats how it is with my car and I thought all 99-04 v6's were that way. Get the codes again, we will probably be able to tell you exactly what is/could be causing that.
14.37 @ 96
Yes some V6s came with that sensor, some didnt. Thats why they say its for 99-03 and dont include 04. But thats still wrong years lol
I dont have that sensor so I cant help you. Do post the codes you get up here and that will help us from there. |
'00 V6 Procharged Mustang
That sensor, the intake air temp sensor, was on 1999 and 2000 3.8 mustangs. Starting in 2001 this became integrated into the MAF and was no longer a separate sensor.
Just go get the CEL code read. That'll tell us a lot more than you'll be able to. I'd suspect that you either come up with a IAT code, a MAF counts code or running lean. In any case you'll know where your problem lies then.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
2000 Mustang v6
so are we sayin the if air is leakin in behind the MAF that im getting in more air than the engine thinks so it might be a lean mixture... im sure its not my 02 sensors(mostly sure)
also nd reason the light would only come on after idle? initially it came on rights after installation during a really long idle before driving 2nd time drove a whole lot like over 300 miles... and it came on after i had been idling for a real long time, ... ill get the codes |
Resident badass
99-00 have external IAT. 01-04 have integrated IAT, meaning its built into the MAF. I have the built in one. Same with mike and demon.
But not really sure what you asking here guy. Be specific.
Put the factory airbox back on and remove the silencer,that snorkel looking thing. Then send that thing back where you bought it then spend your money on something that will give your car more pep.... Like gears and a tuner
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
2000 Mustang v6
ya im not very impressed but i wasnt really expecting anything crazy.
my next performance mod will most likely be gears |
#16 | |
![]() Pretty.............................Slow Mods: Apparently more than 250 characters |
2000 Mustang v6
Well i know its been a while but i got the code
P0171 System to Lean Bank 1 what do you guys think? |
#18 | |
Dancing Naked In The Rain
And tlok + tuner. Don't skip the tlok or you'll be paying for the same install twice when you realize you should have done it in the first place. And you'll need the tuner to recalibrate your speedo/tach.
If you got the same CAI as me (the cheap one from AM) it probably came with a new PCV hose that doesn't secure to the "nipple" that attaches to the valve cover. If that slipped off then just super glue it on (mine has held up for over a year). ![]() That black hose coming off the CAI is the one I'm talking about. It's the new one that came with my CAI and wouldn't secure to the valve cover "nipple" without an adhesive.
2000 Mustang v6
mcqueen everything u said i have checked. Only issue is my pcv hose is really dryrotted.
i used the one that was already in my car because the one from AM didnt wanna fit. Might be because of how cold it was... This though--- "If you rotate the tube connecting to the throttle body it will slightly slip out of place and let air in (usually at the bottom)" i am not for sure of but i have checked and found no leaks. Also my IAT was what i thought i may have messed up. Could it throw a code like that or what would the code be. |
#20 | |
I don't think it's the IAT. I'm pretty sure that throws a different code because my buddy's 96 F150 has been throwing a code that is specific to the IAT. However, did you put the IAT in so that the plastic bits are pointing towards the sides of the CAI with the sensor positioned that the air easily flows through? And that new PCV hose is a bit of a pain in the ass to get on the CAI. If you warm it up some then it should go on a little easier.
Threads Similar to: CAI problems
| new with temp problems and trans problems | 89Bullitt | 2.3 Mustangs | 4 | September 18th, 2010 03:14 PM |
| problems!!!!!! | fordrangerguy | 5.0 Mustangs | 22 | July 8th, 2009 01:30 PM |
| Big Problems!! | Stangzilla | 5.0 Mustangs | 5 | July 6th, 2008 06:20 AM |
| A/C problems | throwedoff | 99-04 | 3 | September 25th, 2007 07:42 PM |
| a few problems. | 1BADSTANG | 5.0 Mustangs | 6 | September 17th, 2007 10:37 PM |
