#21 |
Resident badass
My .02
Don't cut. Just buy lowering springs. That's coming from a guy who has cut them. And now has lowering springs on the way..
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
#22 |
2000 Mustang
slow@slow
Yeah. Well, ive heard good things from quite a few people about cutting springs. And its not a big deal for me because my car is just a dd right now. But if i ever owned a car with over 300rwhp, id definetly buy performance springs.
#23 |
Resident badass
Mines a DD. I fucking hate it. If you do cut them. MAKE SURE THEY DON'T HEAT UP!!
Don't cut more that 3/4 of a coil.
#24 |
2000 Mustang
slow@slow
I assume they warped? How did you cut them?
#25 |
1996 Mustang
I take myself way too seriously.
If your springs get heated incorrectly the spring steel stiffens up and the springs can snap under a load
Your car is going to ride like ass if you cut the springs. Especially if you cut one more than the other. Since those springs are progressive, you're going to make one side much stiffer than the other. I suggest buying new springs, check out ebay. |
#26 | |
Better than ONLYaUNCfan's
2012@lightspeed
Had the rear stock cut and it was a bumpy ride...
Getting new lowering springs wouldn't solve the dilemma...
Formerly, AhobosCheese and Cheddars.
#27 |
1996 Mustang
Why? I buy from ebay all the time, and have never had a single problem. I put together the turbo charger on my old 240sx on ebay parts and that fucker is still pumping 14psi for my buddy that I sold it to.
Just use common sense on what you buy, and beware of used and generic China made stuff. As far as the sagging, pull the springs off both sides and check and see if one is higher than the other, then swap the springs sides. If the sagging doesn't switch sides....I'd look into your sway bar and end links Last edited by fmxona500; January 27th, 2011 at 10:40 PM. |
#28 |
2012@lightspeed
My spring problem. Or more a control problem.
![]() Last edited by BlueScreaM; January 28th, 2011 at 10:21 AM. |
#29 |
Bringing Yellow Back
^wtf how did that happen
i cut 1 1/2 coils out of the front of my car ( hold me over till i get new cc plates so i can put my coil overs back on) i have had ZERO problems with mine
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#30 |
2012@lightspeed
Ive dont know the springs were the same length and all and I havent cut the springs either.
#31 |
perhaps on is not set in the a-arm right, the end of the spring might not be in the little pocket
#32 |
99 V6 BASE
NEVER RACED THIS ONE
mine saged on left side with old springs and new eibach pros. just put a shim/spacer on top of spring and be done with it.
#33 |
Resident badass
Mine bottoms out like crazy. I cut a coil and removed all the ISOs. It also rides like shiiiiiit.
I'm switching to FR B-springs and New ISOs all around.
Threads Similar to: Alignment has finally pissed me off.
| Alignment??? | naza | 99-04 | 10 | October 20th, 2010 12:51 AM |
| Alignment off | sniperd | 5.0 Mustangs | 20 | September 17th, 2009 11:47 AM |
| alignment | Toph6888 | V6 Mustangs | 13 | February 23rd, 2008 04:24 PM |
| ? About Alignment | mustang fanatic | 2005 - 2010 | 4 | December 17th, 2007 10:34 AM |
| Alignment? | Mrdestboi | 2005 - 2010 | 5 | December 10th, 2007 06:24 PM |
