Throttle Body
This is the only place I think I could post this question. Will I get anything by changing the throttle I was just looking on www.americanmuscle.com for parts for a v6. I know it controls the amount of air flowing into the engine. Will I gain more air flow from installing that or is it just the same part thats already in there? also if it does change anything will i feel it at all?
48.47@ 12.58
not worth the cash unless your s/c man... even for us v8 guys
yep worthless even with a s/c, might save you a little boost, but 400 is all you should ask from a stock 4.6 anyway
03 GT leather seats for sale or trade for racing seats, Looking to buy: subframes, tower braces, control arms, bypass/BOV, 42# injectors & MAF Trade/ Sell Predator 4 SCT (wrong part of the country) |
So say I installed a ProCharger on my v6. It says you get 40% to 60% more hp gain. So the highest horsepower I can reach would be 336 which is the 60% gain. Would I need to forge my internals or can it handle it with out any problems at all?
1) 4.10 gear for 7.5" rear end 2) Underdrive Pulley 3) Mustang SLP X-Pipe (catted) 4) Procharger 5) cams at some point maybe I though i would try to get this out of the way =D the cams i might not do if I get the Procharger, because thats cutting it pretty close i would say to the 400 point. *edit I forgot to mention heads I'm not sure about those yet any suggestion or should i go look in the exhaust forum? |
#5 | |
48.47@ 12.58
1)you might want to reinforce the rear end if you plan on over 350rwhp 2) you can't run U/D pulleys with any s/c 3)good mod 4)another good mod 5)if you get cams and your going to be s/c'd make sure to get custom grinded blower cams. 6) just p/p the heads. did i miss anything?
MM's Resident Ricer
2006 Scion tC
13.001@113
below 400 hp your block will be fine, forge internals you will need a beefy rear end. If you have an auto get a shift kit for strength purposes, and no UD pulleys with a s/c
ok so I can't put a U/D pulley on with a S/C. How would I go about forging my rear end? Could a 8.8" on my v6?
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah you will need an 8.8 for that much hp I would get a 31 spline upgrade and a eaton LSd as well
thats going to be some much work
Could I get this anywhere besides a junkyard? Personally I'd like to get the GT, but I cant afford the payments on it. argh why can't they all just have a 8.8" rear
MM's Resident Ricer
2006 Scion tC
13.001@113
doesnt fit with a 2005+
nvm I found it
http://www.speedconcepts.net/product...roducts_id=728 good deal except i want to put 4.10's on there. |
MM's Resident Ricer
2006 Scion tC
13.001@113
lord that thing is cheap. Just get 4.10's as well and have them installed in it as it is being put on.
#14 | |
He said forge his rear end...
last question how much you think it will cost to install this? 500?
MM's Resident Ricer
2006 Scion tC
13.001@113
500-800 probably
#17 | |
Threads Similar to: Throttle Body
| Throttle Body | Snipe061 | V6 Mustangs | 8 | September 11th, 2007 03:28 PM |
| Throttle Body | autoranch | 96-98 | 4 | August 7th, 2007 08:24 PM |
| bbk throttle body | dumps | 2005 - 2010 | 4 | March 26th, 2007 07:02 PM |
| new throttle body? | AFtriathlete | General Tech | 18 | March 20th, 2007 12:14 AM |
| throttle body | noppe180 | 96-98 | 2 | November 4th, 2006 05:57 AM |
