Need Opinions and Suggestions
Old January 30th, 2011, 06:42 PM   #1
bluemonkey's Avatar
2011 Mustang V6
bluemonkey is on a distinguished road
Hello everyone.
I'm rather new here. I just purchased a new 2011 v6 a week ago. I got the cheapest one possible... no leather seats... no sound system... no ambient lighting.
I was driving the other night and thought that it would be really cool to have like a ambient lighting over the pedals and on the passenger foot area .. as well as under the driver and passenger seats. I thought that I could use like ice blue led strips so that it would match the gauges as well as the center console controls.
I have no idea where to start though. (wiring, purchasing, what products to use... etc.)
Any help would be greatly appreciated
Old January 30th, 2011, 06:50 PM   #2
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Get some cheap LED's off eBay, they're a lot less expensive then the ones you'd buy at AutoZone. 3M tape under dashboard.Then you just wire them into the fuse box on a key on fuse.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old January 30th, 2011, 06:57 PM   #3
Dancing Naked In The Rain
mcqueen's Avatar
You can pick up LED strips really cheap on eBay. They generally come from China, but mine have lasted almost a year with no problems. I've also written a guide on the install: Mustang Footwell Lighting
The guide is specifically for 99-04 models, but the general process is pretty much the same. You'll need 4 LED strips, some wiring (I think I used 16 or 18 gauge plus I color coded mine -red for positive, black for negative), wire cutters, electrical tape (or heat shrink tubes and a heat gun), a switch if you don't want the lights on all the time, and a soldering iron + solder if you don't want to do the old twist together method. You'll just have to find a power source to tap into (I personally used a cigar lighter/accessory port, but people have used the radio harness and other sources).
Edit: These are the kind of strips I recommend: http://cgi.ebay.com/ebaymotors/Flexi...item230cd0bdb7
There is a different kind that has the LEDs sticking much further out but they put out a lot more light, and the ones in that link will put out more than enough (I actually covered a few of the LEDs to tone it down). 15 SMD/12"/30cm is the length I recommend as well. Lights up the footwells very nicely. Not to mention you can pick them up dirt cheap (usually $2 shipped per strip or $3 shipped for sets of 2 strips).
Also, doing it this way will save you a lot of money. There is an "ambient lighting kit" for 05+ models that a few companies sells. It runs right around $200+ and the only difference is that you get the "string" lighting for the cup holders. I know for a fact you can get a strip of "string" lights at Advance Auto for maybe $25 if you really want to go with that.
My Hubpages
Hey.. r u really a tranny??
Old January 30th, 2011, 07:58 PM   #4
bluemonkey's Avatar
2011 Mustang V6
thanks
Threads Similar to: Need Opinions and Suggestions
Opinions and suggestions GTRumble Racer's Corner 2 September 6th, 2010 06:18 PM
Need some opinions on which rims to get! Any suggestions welcome! mrsinister2424 99-04 34 March 2nd, 2009 07:55 AM
Bought a S/C and need some opinions and suggestions. mustangmanic The Clubhouse 25 February 9th, 2009 10:20 AM
Looking for Opinions/suggestions on upgrades AnimalCrackers 2005 - 2010 20 July 4th, 2007 03:13 PM
any likes, dislikes, opinions, suggestions? notsoslo5.0 5.0 Mustangs 18 April 8th, 2007 05:01 PM
