2000 mustang gt
transmission help!!!
does anyone know of a sticky about transmission removal and reinstallation for throw out bearing changeout. also does the ford racing tob need to be greased or packed or anything?i hav an 04 3.9 v6. thanks
MM's Official Lucifer
Remove shifter bezel inside cabin and remove shifter from top of trans.
Remove exhaust, which is pretty simple, 6 bolts total and 4 electrical connectors (for stock exhaust). Remove driveshaft, I beleive 4 bolts at rear end, then it will slide out of end of trans. (I would drain trans in very beginning actually so less fluid spills). You'll have some fluid leak out of d/s. Then remove trans from bellhousing, 4 bolts at trans brace and I believe 6 bolts at bellhousing, don't forget electrical connectors as well. You can leave the b.h. on to just replace the tob. Just take out the clutch fork (you'll have to disconnect the clutch cable at the b.h.). There's an inspection cover on the b.h. you can remove to get the fork out. Grease the new tob on the inside diameter and also on the face that contacts the clutch fingers. Clip new tob onto clutch fork, install into b.h. and do reverse of all steps to reinstall everything. Don't forget to refill trans with proper amount of fluid. **These instructions are from a 2000 3.8L, but should be exactly the same for you.
2000 mustang gt
thanks... what kind of grease should i use?
2000 mustang gt
2000 mustang gt
thank you!!! what type of grease should i use?
Resident badass
multi-purpose grease. A long ass extension will really help getting the trans bolts out. At least it helped for me.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
Yeah I think I just used some lithium grease that was sitting around the garage...
2000 mustang gt
thanks for all the advice. and yea i hav alot of extensions... i took a t56 out of a firebird and needed em.
No prob, lemme know if you need nething else... went thru the whole process and there's def. some things that make it easier the second time around.
#11 | |
Resident badass
At least I had a lift for mine and the truck..
#12 | |
Resident badass
2000 mustang gt
thanks for all the help!
2000 mustang gt
does anyone know torque specs for all the trans bolts?
Resident badass
Tight enough?
2000 mustang gt
lol
I have the info I believe, but I'm not home now. If I get on tonight I'll post them up. Def. not just "tight enough", I'd spec them right.
2000 mustang gt
cool thanks... could use the info
Threads Similar to: transmission help!!!
| Transmission | zinc02GT | The Clubhouse | 7 | September 20th, 2009 09:18 PM |
| Transmission oil... | joshfrisco | 2005 - 2010 | 0 | August 28th, 2009 01:24 AM |
| Transmission | Haseeb718 | 99-04 | 20 | May 27th, 2009 03:07 PM |
| Transmission Help!!! | Mstngdtb | 5.0 Mustangs | 9 | September 7th, 2007 05:19 PM |
| F*** I need a transmission!!! | 99spaded | 99-04 | 32 | August 26th, 2007 11:15 PM |
