2000 m112'd 3.8
fog light install
so im going to install my fogs probably this week but what size are the bolts that go into the bumper I think theres six total but I couldnt find any fastener kits for it
the fogs just use a screws to hold them in and adjust...the bottom one does use a 6mm though
I'm doing it wrong
04 Grand Cherokee
You got a GT front bumper? Or you just going to cut the things that are blocking the fog light holes? I suppose with a little work you could leave them there and mount the fogs behind them but idk how they would look.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
#4 | |
Wing on, wing off...
JULY 2011 ROTM
You'd have to cut those plastic grille thingy off... Maybe sand off the rough edges for a clean OEM GT bumper look.
![]() As for the tabs (I can't remember the name for it) where the screws attaches to, I got those from pepboys... ----If your fog lamps didn't come with those... Are you using aftermarket fog lamps? Those suckers don't come with the tabs... I had to do all the wiring... I got a $20 universal ford fog light wire harness off if eBay... Then just connected it to an OEM fog light switch...
![]() SIG BY WABASHACOBRA99
Moderator
speed clips
![]() ![]() BUILD 2 IN PROGRESS |
JULY 2011 ROTM
2000 m112'd 3.8
I have a stock bumper and I would just cut them out but the fogs are aftermarket I bought online but never installed them they look like this(
JULY 2011 ROTM
Pepboys!
2000 m112'd 3.8
I have no idea were a pep boys even is Ive never seen one on long island ill have to look it up
2004 Mustang V6
Copy and paste from instructions.
Foglight mounting equipment (from Pepboys, part # in parentheses): 1/4" 'U' Nut (#45818) (two pkgs) 5/16" 'U' Nut (#45414) 1/4 x 1" Body Bolt (#45596) (two pkgs) 5/16 x 1" Body Bolt (#45590) You can go to Advance Auto Parts. The part numbers matched when I did it. (If they still do) Last edited by Oxy3.9; February 3rd, 2011 at 11:27 AM. |
'00 V6 Procharged Mustang
Any auto parts store will have them.
Whenever I've went to buy some I've found them just out in the main part of the store, not behind the parts counter.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
2000 Mustang
slow@slow
This. 6er, i think you'll like what i did to my front bumper. I just gotta find time to get it cleaned up and take some pictures.
#14 | |
1998 V6 Mustang
Threads Similar to: fog light install
| Fog light install | Puffy93 | V6 Mustangs | 11 | December 10th, 2010 01:06 PM |
| hid fog light install help | 01MGGT | Audio/Video | 2 | February 2nd, 2010 12:08 AM |
| abs light on after install of 275/60/15 | kennyGT | 99-04 | 5 | February 9th, 2009 11:38 AM |
| Fog Light Install Help | moneygreenstang | V6 Mustangs | 0 | July 10th, 2008 09:18 PM |
| Fog Light Install | Ticket-Me-Yellow | Visual | 12 | April 2nd, 2007 09:31 AM |
