Shaking while driving
Old February 4th, 2011, 07:26 AM   #1
Ain'tNobodyGotTimeForThat
SlowbaltSS's Avatar
2004 Mach 1
SlowbaltSS is on a distinguished road
I have a 1999 Mustang v6 with the 4-speed auto. I noticed for a long time now that when I reach 40 mph, the rpms stay at about 1200 and the car creeps in terms of acceleration, there is also a vibration. This happens until 50 mph and it only happens in 4th gear. The only way I can effectively accelerate is if I push the gas pedal down until the car down shifts into 3rd. This is now a major problem as most of my commuting is at 45mph. I cleaned out my IAC and MAF with throttle body cleaner, no improvement. Any ideas what could be wrong?
Old February 4th, 2011, 09:25 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
From those symptoms, it sounds like torque converter shudder. How many miles are on the car, and when was the transmission fluid/filter changed last? Have you checked the trans fluid level? Is the fluid burnt at all?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 4th, 2011, 10:44 AM   #3
SlowbaltSS's Avatar
2004 Mach 1
I dont recall the exact date, but within a year ago I had the tranny fluid changed. The mechanic said that if the fluid was burnt or something, changing it would do more harm than good, but he said it was ok to change and did that. And the engine has a little less than 120k. I try to make it a habit to check my fluids every month, haven't checked yet for February I'll take a look.
Old February 4th, 2011, 10:46 AM   #4
Tang Stang's Avatar
And as for the other questions?
Old February 4th, 2011, 10:53 AM   #5
SlowbaltSS's Avatar
2004 Mach 1
Nope, trans fluid is clean and full. I think my car is just a lemon. A sun-bleached, black, one wheel drive lemon.
Old February 4th, 2011, 11:23 AM   #6
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
My car did tht only because when I had my old-er mustang (97) it was also and auto and the shift point for 3rd/4th was approx 40/45mphit would shift into 4th then "bogg" down a little mabe shake a little but thts because again when my auto shifted into 4th it was oly doing slightly and I mean slighty pver 1k rpms so I said eff it and took it out of o/d till about 50....the shift point in all the autos I drove sucked D***
Just saying and my .02
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old February 4th, 2011, 11:54 AM   #7
SlowbaltSS's Avatar
2004 Mach 1
Which is why my next car will be a Mazdaspeed 6 or a 04 Mustang Mach 1 (Manual).
Old November 19th, 2011, 01:26 PM   #8
Bobby00000's Avatar
1999 Mustang 35th edition
Bobby00000 is on a distinguished road
My 99 did exactly what your talking about, buy some dr tranny from Oreileys its like 7 bucks add that where your transmission fluid goes and that will fix the shudder in the torque converter temporarily, that stuff really does work wonders!! I went and had my transmission switched out and ever since i did that i havent had a problem, i would advise doing this if you plan on keeping the car, i got my transmission for 100 bucs and paid some jackwagons who messed up and caused mine to leak which was 200 then another 150 to fix their screw up but other people quoted me 150 to do a transmission swap, i know around here ive seen transmissions for 150 - 200 so if you get it done right you could be looking at 300 - 400 for a transmission and a swap, i ended up paying over 500 cause my guys jacked it up and didnt replace my o ring on the dipstick and all my gasgets. hope this helps man
Old November 21st, 2011, 09:58 AM   #9
2001 v6 premium
xtreme 2 will become famous soon enough
Send a message via AIM to xtreme 2 Send a message via MSN to xtreme 2 Send a message via Yahoo to xtreme 2
Could it be that you just have a slow V6 and you are in overdrive at 45 mph?
Screw it, coming to play with the big boys...
5.4L Vortech COMING SOON!
Old November 21st, 2011, 03:18 PM   #10
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
This thread is old news
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old November 21st, 2011, 04:01 PM   #11
2001 v6 premium
wow, I gotta start looking at the dates of the guy that posted before the guy that last posted...
Old January 2nd, 2012, 11:56 PM   #12
SlowbaltSS's Avatar
2004 Mach 1
That car is my younger brother's problem now :p
Threads Similar to: Shaking while driving
Shaking... EleanorGT500 V6 Mustangs 3 December 13th, 2010 11:44 AM
door/window shaking when driving jmscobra V6 Mustangs 9 April 26th, 2009 12:23 AM
shaking mustang1072 V6 Mustangs 21 March 15th, 2008 02:10 PM
Something shaking... 95blackbeauty 94-95 2 January 29th, 2008 01:43 PM
Shaking? tkwhitestang 94-95 8 January 6th, 2008 01:04 AM
