windstar install - Page 2
Old February 10th, 2011, 02:38 PM   #21
Bram-Stangg's Avatar
2001 Mustang v6
Bram-Stangg is on a distinguished road
Originally Posted by Mr. Red Pony View Post
Did you get a 65mm TB?
no normal tb.
mods installed; windstar kit, bbk fendercai, 3.73 gears, tlok, smoked heads, 3piece gril delete, shorty antenna, black fuel cover.
mods waiting to be installed; stainless steel dual exhaust, spacers, chin spoiler, rear bumper inserts
Old February 10th, 2011, 02:42 PM   #22
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Hmm.
Get some pics up man.
271rwhp N/A V6
Suck it.
Old February 10th, 2011, 03:48 PM   #23
2001 Mustang v6
when i got time i shoot them, >.<
Old February 10th, 2011, 04:10 PM   #24
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
Hmm.
Does the 65mm TB throw a code or something?
Build Thread
Old February 10th, 2011, 04:33 PM   #25
2003 Roush Mustang Stage1
Therealtater is on a distinguished road
it shouldn't throw a code, at least it didn't when I swapped it out on my truck, just modifies how much air is getting to the motor
Old February 12th, 2011, 05:54 AM   #26
2001 Mustang v6
damn.. started to snow here like hell but thats besides the point,
so some underhood pics;
you can see in the last pic how the hood still hitting the elbow and a little bit tb
Old February 12th, 2011, 08:06 AM   #27
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
If you go with a GT TB right off a GT, there is an air port on the back that allows for a vacuum leak. You have to fill and mill it.
271rwhp N/A V6
Suck it.
Old February 13th, 2011, 12:34 PM   #28
2001 Mustang v6
oke, this is fucked up.. its getting worse
i managed to get tb cleaner and i will clean the sensors, but seriously..
its revving for itself alot :s also hearing a psssjjj coming from under the hood.
when i pop it and look for the sound i cant find it? al hoses are tight, to make sure i did clamp every hose, so i dont think its a bad connection for that.
could a bad iac really cause this? damn..
Old February 13th, 2011, 05:22 PM   #29
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
I think you have a problem at the TB base gasket. spray something around it while running. i filled my manifold base in to give more gasket support and to eliminate any chance of vac leak were o-ring use to go up. i also had to notch my angle plate because the spring was always getting caught between plate and TB causing vac leak.
Old February 13th, 2011, 09:33 PM   #30
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Check your extensions. I had a similar problem and ended up redoing my extensions which solved my problem. The pssssssss noise is probably just the cai.
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old February 14th, 2011, 11:00 AM   #31
2001 Mustang v6
thanks! i will gonna try that
what did you use to fill it?
i will check that to. i might be an electrician, but i could make mistakes to :p
this pssj sounds different then the cai. it sounds a bit like a blowoff valve lol.
il let you know if it helped
btw, when you start the car, is your fan blowing like hell too?
Old February 14th, 2011, 12:05 PM   #32
99 BLUE V6's Avatar
99 V6 BASE
JB weld - and thats what my vac leak sounded like also
Old February 14th, 2011, 12:12 PM   #33
2001 Mustang v6
thanks, going to find something similair in holland when thats the prob
Old February 15th, 2011, 08:27 AM   #34
2001 Mustang v6
oke im a bit confused now
i think the problem is 90% solved now
i sprayed some leakfinder around my tb, didnt notice that it leaked, BUT
when i take closer look and trying to find the pssj, i noticed something srsly stupid
apears i forgot to tighten one bolt from the upper intake, i mean it was in there, but it could have a few strokes. so after that, it idles perfectly
i know i know.,. dumb as fuck, but the bolt was hardly visible
when for a testdrive, its not revving for itself anymore, only a tiny bit when i have the airco on, supose thats normal? also sometimes a sort of cry or howl hearing from my windstar.
anyway, its still touching my hood a bit.. any ideas? i dont feel like buying another hood, because its very hard to find here
Old February 15th, 2011, 09:42 AM   #35
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
dont they have a piece that angles it down?
238rwhp/263rwtq
Drew's Build Thread
Old February 15th, 2011, 11:17 AM   #36
2001 Mustang v6
yes i have..
maybe i need to move my engine a bit down lol
Old February 15th, 2011, 12:55 PM   #37
SlowSix's Avatar
2001 V6
15.47@89.57
If the noise you're still getting is a whistle ish noise when you're on the gas its just the intake tubing whistling. And idk my car revs up a little bit occasionally when the air is on I don't think its anything to worry about.
Build Thread
Threads Similar to: windstar install
Help With Windstar Install southfour! V6 Mustangs 74 September 3rd, 2010 12:17 AM
99 03 Windstar Install 99 BLUE V6 V6 Mustangs 31 August 20th, 2010 03:59 AM
Windstar install moddedstang93 V6 Mustangs 12 May 20th, 2010 12:57 PM
Windstar install time Mr. Red Pony V6 Mustangs 61 April 16th, 2010 01:04 AM
My Turbo install with Windstar upper swap WLJohnson05 V6 Mustangs 398 November 29th, 2008 06:03 PM
