Sensor Placement
Old February 10th, 2011, 05:16 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Sensor Placement
Ok well I was talking in class today with my teacher about O2 sensors. And he was asking me about my wideband in my car. He asked where I placed it and I placed it after the cat in the rear O2 spot since I have my rear O2s shut off. He didn't understand how it would read the right amount of oxygen since the cat would be changing the exhaust mixture.
I didn't have a good answer. Is it ok to put it after the cat or should I move it? It seems to read just fine. I just want to kind of figure out why it doesn't matter so I can tell him.
Thanks.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 10th, 2011, 07:01 PM   #2
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
The cats might alter it a little but you should still get a good reading , I would go for the precat sensors to be safe , or better yet get longtubes and throw out the cats
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old February 10th, 2011, 07:03 PM   #3
not haveing it close to the precat location can cause idleing issues down the road..can cause your car to run lean or rich...at least that's what i've noticed from putting the midpipe on my car and a few of the v6 guys as of late..i can understand your teachers confusion
Old February 10th, 2011, 08:38 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Wideband is supposed to be before the cats.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old February 10th, 2011, 08:48 PM   #5
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Before the cats would be the correct place to put it.
I actually asked my tuner the same question since he was pulling the AF ratio from after my cats. His response was that 10yo cats won't be doing much to alter it but he's aware that he might have to adjust for them a little.
It ended up his after cat reading was very, very close to my wideband reading that is installed pre-cats.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old February 11th, 2011, 09:20 AM   #6
Codeman's Avatar
Ok thanks, I thought that it seemed weird. I wasn't really thinking at the time of installation. I just remembered someone saying they put it in the rear o2 spot. Ok well I will have to move that around after I do my cam so I can get a correct reading for datalogging. Thanks.
And I plan on maybe getting headers this summer if not maybe in the winter we will see how funds are.
Threads Similar to: Sensor Placement
Hood Pin Placement Maluther 2005 - 2010 34 July 15th, 2010 08:09 PM
Ipod placement? 06VistaGT 2005 - 2010 37 October 27th, 2009 05:56 PM
o2 sensor placement wishIhada5.0 99-04 18 October 27th, 2009 10:31 AM
Maf placement? DickH 99-04 0 May 15th, 2009 12:15 AM
Bung placement? 07 STROKER 2005 - 2010 39 May 28th, 2008 08:37 PM
