High Fuel Pressure
Old February 13th, 2011, 12:44 PM   #1
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
High Fuel Pressure
Anyone ever experienced this?
Idle, Part Throttle, and WOT are all around 65 PSI which is crazy...
The car is leaning out and lacks power at higher RPM's - knocking around 5k RPM but runs at 14.7 part throttle all day long until like 4k RPM
I've replaced everything except the FPDM and the ECU... Gaskets, Fuel Tank, Fuel Pump, Fuel Pressure Sensor, Fuel Supply Line, Injectors, Injector O-Rings...
Someone say they've seen this before and replacing the FPDM fixed it and my life will be at ease...
Thanks for any help!
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old February 13th, 2011, 01:43 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
There is a module that controls the duty cycle of the fuel pump and thereby regulates the pressure. I believe it is located in the trunk.
Old February 13th, 2011, 01:48 PM   #3
This may help
Diagnosing Returnless Fuel Injection Systems
Old February 13th, 2011, 08:50 PM   #4
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
Changed the FPDM - still no luck. Still showing 65+ PSI at the rail and yet I can't get enough fuel to the motor at high RPM's...
Changed the tune to run super rich at WOT Mid to High RPM and still leans out to over 15.0 at 4k RPM
Any other ideas? ECU?
Old February 26th, 2011, 01:04 PM   #5
ddaniels750's Avatar
2003 Mustang GT
13.2@107
ddaniels750 is on a distinguished road
I'm having the same problem. FP reads a constant 90 PSI and the FPS voltage is 5.00 volts
Threads Similar to: High Fuel Pressure
high oil pressure nic15 96-98 6 September 25th, 2010 02:31 PM
Fuel Pressure To High...... BLUE91GT 5.0 Mustangs 2 April 22nd, 2010 02:15 PM
Fuel Pressure To High BLUE91GT 5.0 Mustangs 10 December 1st, 2009 11:57 AM
When intalling MSD a High Pressure Electric Fuel Pump rasalibre 5.0 Mustangs 3 September 26th, 2009 12:42 AM
