Ford Ranger Rear End? - Forums at Modded Mustangs
post #1 of 10 Old February 13th, 2011, 10:08 PM Thread Starter
MOAR BOOST
SlowSix's Avatar
So today one of my friends told me that some of the ford rangers have a rear end with 4.10s in them.
Is this true? Any idea if I took the rear end what the width is/ if it would work on my car? Could I just take the center diff out without using the whole rear end?
Turbo Build Thread
Status: At the paint shop
SlowSix is offline
post #2 of 10 Old February 13th, 2011, 10:19 PM
Ford Ranger Rear Axles - The Ranger Station
It says they can be found with either a 7.5" or an 8.8" from 1990 on up. You'd have to look at the diff cover to know for sure.
iammclovin804 is offline
post #3 of 10 Old February 13th, 2011, 10:20 PM
post #4 of 10 Old February 13th, 2011, 10:59 PM Thread Starter
MOAR BOOST
SlowSix's Avatar
Hmm. Any one have any idea if it would fit on a stang? I read that the diff is offset to one side on the rangers?
Turbo Build Thread
SlowSix is offline
post #5 of 10 Old February 13th, 2011, 11:10 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
the only thing you could use is the differential its self depending on if its a matching size. (7.5 of 8.8) The actual housing will not for your car. Totally different than a car housing
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #6 of 10 Old February 13th, 2011, 11:12 PM Thread Starter
MOAR BOOST
SlowSix's Avatar
Damnit. I was hoping I could pull a 8.8 from a ranger for cheap.
I want an 8.8 but don't want to pay out the ass like everyone seems to want for them around here.
Turbo Build Thread
SlowSix is offline
post #7 of 10 Old February 13th, 2011, 11:22 PM
The Big Spoon
jessemachone's Avatar
to answer your question, yes, you can take the center section out and the pinion gear and install it in your rear if you already have an 8.8.
Some of the rears are 31 splined axle shafts so you may need to take the drivers rear shaft as well. (I am pretty sure that the passenger side is too long for a stang and you will have to look for another driver's side shaft.)
I am doing some research as well. I am getting a ranger rear complete with discs and installing what I can from it into my stang. (I am going to have to make up some brackets for the brakes cables at the very least)
Try googling 8.8 swap. There is a ton of info out there for swapping explorer / ranger rears into jeeps. You can most likely get all of your info there as far as ratio / codes / spline count. Make sure you get one with an LS marking on it (limited slip) otherwise it will be a waste.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
jessemachone is offline
post #8 of 10 Old February 13th, 2011, 11:30 PM Thread Starter
MOAR BOOST
SlowSix's Avatar
Hm. Seems like it might be easier to just try to find a 8.8 out of a 99-04.
Turbo Build Thread
SlowSix is offline
post #9 of 10 Old February 13th, 2011, 11:35 PM
The Big Spoon
It would be but they are hard to find and when you do find one, they will be asking too a pretty penny for it.
Do you have an 8.8 already?
Black Stang Crew
post #10 of 10 Old February 14th, 2011, 01:10 AM Thread Starter
MOAR BOOST
SlowSix's Avatar
Originally Posted by jessemachone View Post
It would be but they are hard to find and when you do find one, they will be asking too a pretty penny for it.Do you have an 8.8 already?
Thats the problem.
And no, v6's have a 7.5
Turbo Build Thread
SlowSix is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/204071-ford-ranger-rear-end.html
Ford Ranger Rear End - Carmagnify This thread Refback June 16th, 2012 01:32 PM
