Code P1000
Old February 16th, 2011, 04:38 PM   #1
v6 stunna's Avatar
2000 v6
v6 stunna is on a distinguished road
Code P1000
P1000 is saying the some test is not complete? what does this mean?
And i have another 02 sensor code but should i worry about replacing the sensor right now? my gas mileage hasnt changed..
Old February 16th, 2011, 04:43 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
P1000 means literally what you said, the tests aren't complete. This is the code you'll get for 50-100 miles after you disconnect your battery and reset your computer. Keep driving and it will eventually go away.
For your O2 sensor code, is it upstream or downstream? If it's upstream, replace it. If it's downstream then it's really only monitoring whether or not the rear cats are working properly and, imo, a waste of money to replace.
My Hubpages
Hey.. r u really a tranny??
Old February 16th, 2011, 04:48 PM   #3
1996 Mustang V6
trashpickinman is on a distinguished road
After removing the battery, or reseting the OBDII readiness monitor, P1000 will come up. It basically means that your emissions sensors and monitors haven't been driven long enough. Technically there is a set of procedures to drive around to remove the P1000, but basically drive around normally for 30 minutes or an hour or so.
What other code are you getting? And I would probably wait until after the drive cycle is complete to see what other codes come up.
edit: ^ Basically what he said!
Old February 16th, 2011, 04:53 PM   #4
v6 stunna's Avatar
2000 v6
i dont have any bottom cats so no i have no downstream senors..its my right upstream sensor...how necessary is it to replace it?
Old February 16th, 2011, 05:03 PM   #5
1996 Mustang V6
What code are you getting? With no downstream cats and sensors, have you done a tune to delete them or are you running MIL eliminators?
Old February 16th, 2011, 05:11 PM   #6
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Upstream, needs to be replaced soon as possible.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old February 16th, 2011, 05:25 PM   #7
v6 stunna's Avatar
2000 v6
I cant bring the. code off tha top of my head but its my right 02 sensor
Old February 16th, 2011, 05:34 PM   #8
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Right front..
Change.
Old February 16th, 2011, 06:43 PM   #9
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Your P1000 isn't going to go away until you get all your O2 codes taken care of which you should definitely do. After that it'll be able to finish its tests after a bit of driving and go away.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old February 16th, 2011, 10:41 PM   #10
v6 stunna's Avatar
2000 v6
What test i dont get that?
Old February 16th, 2011, 10:50 PM   #11
Your ECU automatically runs tests to make sure everything is functioning correctly. If everything isn't(such as your O2 sensor) then it will throw another code and not finish its testing.
Go google P1000 if you want more specifics.
Threads Similar to: Code P1000
P1000 trouble code setting off my check engine?!?! trueblue02GT 99-04 17 October 25th, 2011 08:07 PM
p1000 code hardhitter 99-04 28 July 23rd, 2011 12:00 AM
P1000 njstang 99-04 4 April 17th, 2009 02:39 PM
p1000 touble code and motor won't start texasd18e 99-04 29 September 18th, 2008 12:07 PM
codes p1000 and p1605 gtdan 96-98 8 August 19th, 2008 04:49 PM
