LinkBack (1) | Thread Tools |
#1
2000 Mustang
slow@slow
Parking brake stuck on?
So today when i was driving, i noticed my parking brake on. It seems like when i give it gas the brake light comes on. It doesnt come on until i hit 1300-1500 rpms. Then if it drops down below those rpms, it shuts off. I can also shut it off by hitting the brake fairly hard. Its weird. Oh, also my handbrake doesnt work. I know nothing about the braking system. Has anyone heard of this before? Or better yet anyone know how to fix it?
1999 mustang cobra
it sounds like the screw thats goes on to the ebrake indicator switch is loose. all you need to do to check it is to take off the center console and thier is a little gadget with a small spring in the back part of the ebrake. make sure that little thing is tight onto the ebrake
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
2000 Mustang
slow@slow
Awesome. Now another question, how do i pull up the center console without breaking it?
2003 mustang gt
or it could be you don't have enough brake fluid happened to me once. check that before anything else.
1999 mustang cobra
yes check the brake fluid first. to remove the center console you need to remove the black thingy that goes around the shifter, all you do is pull it off its attacked with clips. then you will see 2 screws on the center console near the radio on both sides, remove them. then open the box in center console and remove the black rubbers lol on the top of box and take off the inside black box. then you will see some scres at the bottom of the were the black box was at, remove them and pull the ebrake as hard as you can all the way up then take off center console
2000 Mustang
slow@slow
??? this sounds funny to me because my brakes felt funny when i first drove my car today.They pressed in way farther than normal it felt like.
1999 mustang cobra
check you brake fluid and for what ever reason thier is no brake fluid you might need to bleed the brake lines
2000 Mustang
slow@slow
Will do. Thanks for the help guys. Reps
Resident badass
Low on brake fluid. When you accelerate, it pushes the fluid to the back of the master cylinder reservoir. That in turn, turn on the brake light. I wouldn't just top it off though. First check for a leak. Second, see if you need new brakes.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/204538-parking-brake-stuck.html
| How To Fix A Stuck E Brake | Blogs Search Engine | This thread | Refback | April 25th, 2011 12:42 PM | |
Threads Similar to: Parking brake stuck on?
| Parking brake help | moneymo | 5.0 Mustangs | 7 | November 26th, 2010 10:15 PM |
| Baer brake upgrade -- parking brake not working | spoulson | 5.0 Mustangs | 0 | September 30th, 2009 02:01 PM |
| Parking brake is stuck | 99v6stang | V6 Mustangs | 10 | January 29th, 2008 05:14 PM |
| Parking Brake | billb303 | 5.0 Mustangs | 2 | April 12th, 2007 05:43 PM |
| parking brake | wildfaststang | 5.0 Mustangs | 3 | February 1st, 2007 01:58 PM |
