my plans for my Stang after College
here are my plans for my mustang:
Rpmoutlet.com 7.5 GEAR / POSI-TRAC DEAL Features the Following: • FORD RACING Posi-Trac Traction Lok • MOTIVE GEAR 4.10 Ring and Pinion Set • MOTIVE GEAR Differential bearing Kit; (Timkin brg.) Part# MTB380012 $ 355.95 Underdrive Pulley Kit 94-98 Mustang V6 3.8L Add Gatorback Belt: $29.95 Part# MTB386300 Rpm-mustangs.com MAC 1-5/8" Short Tube Headers for 3.8v6 Mustang SKU: MAC-TF38XXST H.T.S. Coated, 1 5/8 inch Shorty Headers for 5-speed and Automatic v6 Mustangs Harland Sharp Bolton 1.73:1 Roller Rockers SKU: HSP-S4173 Pedestal Mount Bolt on 1.73:1 (factory ratio) nonadjustable Roller Rockers I also plan on putting dual Flowmaster 40 series. My car already has a mustangtuning.com cold air intake, does anyone know how much hp a 96 v6 mustang will have with this setup?
![]() my vehicles: 1996 Mustang v6 232 ci 1969 F100 stepside inline six 300 ci www.mooresvilledragway.com www.shadysidedragway.com |
that looks like some good mods. i was planning on doing the gears as well. as far as power, the gears are not going to add any power but will deffinetly make your car faster and for the the headers and rockers they will add a some power. im not sure about the stock horspower on a sn-95 V6 but my 99 V6 with a CAI, and dual exhaust has 163.5rwhp and 200rwtq
1986 Mustang LX
![]() iTrader: 1 reviews
As far as stock HP on a 99 3.8 V6, you would be looking around 193 HP at the flywheel which roughly equates to 168-172 RWHP depending on the dyno you use and weather conditions during the runs. I also have a MustangTuning.com CAI and can tell you that before I added the rest of the mods on my car, the increase was very noticeable, especially on my 3.9. Unfortunately, there isn't a dyno around here for me to find out exactly how much RWHP I currently have, but I can tell you that it's performance seems like it has been upped substantially. I still have some more mods to accomplish before I can call the project done, some of which you are planning to do like the Trac-Lok 3.73's, Underdrive pulleys and headers, however I am going one step further by getting the package deal on the UD pulleys with the programmer and belt. Once I am in a place that has a dyno available (which won't be too much longer as I am leaving this God-forsaken state in 3 weeks and heading to Arizona), I will be sure and post the results after all is completed. A rough estimate I think for the mods that you have listed will probably generate upwards of 185-195 RWHP after tuning if you go that route. My disclaimer on this is that it really all depends on the dyno. Have fun!
1999 Ford Mustang V6
14.79 @ 92.15
id say with a non-split port v6, you should consider long tubes vs. the short tubes if you want power and support for other mods. also, automatic will make less rwhp than 5-speed due to parasitic loss of power in transmission. you would see about 160-170 rwhp compared to the stock rwhp of about 130. do a split port swap and a cam, and you will be running with me.
gears dont add power, just distribute it and multiply it. but intake and full exhaust will give you the rwhp of the stock crank hp, and more than that will just be icing on the cake. remember though, it is a v6 so keep your long term aspirations in mind and write out a full plan of where you want to be in 5, 10. 15 years with this or another car. the car is the 2nd-largest investment in life, so dont dig too deep a hole...
those harland sharp rockers are not really made for our motors geometery, and from my understanding the 1.7 and 1.8's will scrape the guide holes and cause a nice tapping sound, but will work. you might want to look at the pro magnum comp cam stud mounted rockers that supersix motorsports sells, but they are much more $$$
i would also weigh the cost of the posi and gears + install versus swapping to either a takeoff 8.8 or getting a new frpp 8.8?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
14.79 @ 92.15
yea, with over 400-450 rwhp, the 7.5" rear wont hold up on stick shift cars and sticky tires. an automatic should be okay for a while, but the 7.5" rear was prone to breaking on mildly modded old 5.0L
im planning to get it at about 200-250 hp and stop so i dont think it is necessary to switch to an 8.8 just yet. im also worried about long tube headers dragging the ground escpicially where i live (lots of bumps) and i realize that rearends dont generate hp but just added that up there to let you now what i plan on doing and yes my car is an auto
14.79 @ 92.15
i have a 1.25" drop up front and my long tubes do not scrape at speed bumps. i have to treat speed bumps as stop signs though.
lol, ok so here is my updated list:
FORD RACING Posi-Trac Traction Lok MOTIVE GEAR 4.10 Ring and Pinion Set MOTIVE GEAR Differential bearing Kit Underdrive Pulley Kit 94-98 Mustang V6 3.8L with Gatorback Belt MAC ceramic coated longtube headers MAC catted h-pipe Flowmaster American Thunder cat-back dual exhuast Harland Sharp Bolton 1.73:1 Roller Rockers
the most prone part to break in our 7.5's are the spider gears, they will break if you try to run slicks. the mac lt's are a good start, but will dog you in the low end, but those 4.10s will help that. might want to look into a little cam action if you plan on staying n/a.
i was thinking about getting a cam but wasnt sure on who i wanted to get it from.
i would check out the ones comp cams offer, or check with mik at rpm-mustangs.com he offers a mild regrind for a little over $100
14.79 @ 92.15
yeah, and since it is an automatic transmission, slap in a higher converter and then you can brake stand it at say 2500-3k rpms and launch. but doing so with a 7.5" rear is asking to break an axle.
man when i get done with all of this stuff, my car will be a beast!
#15 | |
do you think this cam is good enough? Xtreme Energy Ford 3.8L & 4.2L 255HR112 Cam PART #44-700-9 http://www.powerandperformancenews.c...ry_Code=44-CAM
that cam is what you are looking for if you want to stay n/a
ok, thanks for the help
oh, one more thing, will this exhaust satisfy my needs for a loud car?
14.79 @ 92.15
loud will not sound good. get a cam and long tubes, off road H pipe, and flowmaster 40 series and it will sound okay and be very loud. but without an aggressive cam, a loud v6 will sound like shit.
thats basically what im getting including a new cam but im getting flowmaster's Amercian Thunder system and the h pipe im getting is catted becuase i cant get away with off road pipes here in NC.
Threads Similar to: my plans for my Stang after College
| College | smoke-em | The Clubhouse | 22 | November 5th, 2007 08:00 PM |
| Home from college. Got a pic!! | Littlekim | Pictures | 22 | October 28th, 2007 01:39 PM |
| college internetz | thetrooper31 | The Clubhouse | 13 | October 3rd, 2007 09:43 PM |
| Anyone In College | GT 849 | The Clubhouse | 18 | January 8th, 2007 02:05 AM |
| New plans for the stang | Drgnracin72 | 99-04 | 3 | May 1st, 2006 06:38 PM |
