Possible Cam problems HELP?!?!?
Old February 17th, 2011, 12:10 PM   #1
sterlingboy's Avatar
2002 Mustang V6 Auto
15.2@90.79
sterlingboy is an unknown quantity at this point
Question
So my car has been driving fine since i got the cam in and tuned and all. And it has been about 3 weeks to a month running good and all. But recentley the check engine light came on and when i put in my chip to read the code it just said cylinder missfire in first 1000 revs, and the mechanic I took it to said that it was not just one of the cylinders missfiring so it couldn't be the spark plugs or wires that was wrong with it. And i have contunied to drive it for about three days now and last night there was this loud clicking noise coming from under the hood but only when I was in drive not in park. And as i sped up the thumping/vibrating increased and I was too scared to go over 45mph on the highway, it was that bad! Anyways im taking it back up to Houston Performance Monday so hopefully they will fix it. But my question is do any of yall have any idea what that could be?? And if so do you think it is a real serious problem or not??
Old February 17th, 2011, 02:06 PM   #2
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
Everyone is having cam install problems : /
Build Thread
Old February 17th, 2011, 02:35 PM   #3
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
If its mis firing.. timing issue?? Idk I'm just throwing my thoughts out there...check srings and timing belt and coil
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old February 17th, 2011, 03:40 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
*making a list*
1.) mustang mike
2.) you
But in all seriousness , check the simple stuff first. I think mike had that same code. I think its an install issue personally.
PS:
two places I've always been told not to go in houston were strictly and houston performance, not sure why but i've been given a long lecture several times on both.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old February 17th, 2011, 06:06 PM   #5
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Well you did put the cam in and took it straight to a dyno didn't you?
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old February 17th, 2011, 06:41 PM   #6
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
Hopefully they broke it in first.
H/C/I V6
BMC Member: 12521
Old February 17th, 2011, 06:43 PM   #7
Look Ma! My First Post!
dadejack is on a distinguished road
Broken/cracked Plug?
Old February 17th, 2011, 08:38 PM   #8
1 Wheel Peel
2000 Mustang 393w
Doubting it
2001 GT Vert
2002 Six Banger
Old February 18th, 2011, 02:31 AM   #9
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
... yes same code i got
still dont know the issue ... but ill tell you this, i had noises while driving and before I knew it, i parked the bitch and pulled out a bent pushrod ...
So now i get to take the SOB back apart and start over ...
and btw ... noises arent good ...
oil pressure ? Y/N ?
Dyno tune ?
Chip ...
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old February 18th, 2011, 02:35 PM   #10
15.2@90.79
Im gonna try and get my step dad to tow my shit back up to houston performance tommorow to see if they can figure out what's wrong with it.. and my oil is fine and i had my spark plugs replaced when i got the gears put in about 3 months ago so they should be fine.. Im gonna change the timing belt probably cause mine is kind of cracked. And my motor seems to be shaking pretty damn hard just at idle so maybe i knocked something loose in there or something, cause ALL the noise started right after i went over this violent ass speed bump.. but im gonna fix whatever it is quick cause i dont really have a choice i need my car...but when i figure out what it is ill let yall know! Thanks for the advice, im praying it's nothing too serious
Old February 18th, 2011, 02:44 PM   #11
1 Wheel Peel
2000 Mustang 393w
Timing belt huh
2001 GT Vert
2002 Six Banger
Old February 18th, 2011, 02:46 PM   #12
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
SOMETHING IS VERY WRONG IF YOU HAVE A TIMING BELT, that would be your problem.
Old February 18th, 2011, 02:51 PM   #13
1 Wheel Peel
2000 Mustang 393w
During my cam install I did not come across one of these timing belts you speak of? Perhaps Chris Torres did a motor swap for ya?
Edit: Im sure you meant serpentine belt though.
2001 GT Vert
2002 Six Banger
Old February 18th, 2011, 04:33 PM   #14
95ish5.0
SSteady98's Avatar
1995 GT
Slow
SSteady98 is on a distinguished road
Send a message via MSN to SSteady98
xD Poor guy getting so much shit for the timing belt. how much of an improvement did you see after installing the cam though? hows it sound?
1995 Mustang GT
BBK Shorty Headers, H Pipe, CAI, UDP, 255lph Fuel Pump
Spec Stage 3 Clutch
FR500's all the way around
Cobra R Hood
*Want*
Gears, Cam, TW Heads, Turbo(Last)
Old February 18th, 2011, 05:17 PM   #15
2004,1994,1967
14.37 @ 96
LOLz
Timing Chain maybe ???
Poor kid...
and im sure you would know if your belt was loose ... or broken ...
Timing chain cracked ??? hmm that sounds like a big WTF were you thinking ... almost like my cam bearings ... but they still hold oil pressure !
Looks like your in the same boat i am taking apart your car again !
This shit gets expensive and time consuming ..
227whp N/A V6
Old February 18th, 2011, 05:19 PM   #16
2004,1994,1967
14.37 @ 96
To answer Q above me, I swapped with a catback exhuast and it was very bogged down due to restricted flow and incorrect tune ...
But it did idle much harder !!! Potential for an awesome fucking sound was there ... just not the right exhuast
227whp N/A V6
Old February 18th, 2011, 11:46 PM   #17
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
Oh and you can add me to the list of having trouble with a cam, ESG =P haha remember mine? and we never really found out what the exact problem was. All I know is when I took it out, the car ran perfect again. And it could not be tuned with it. I might try again though, a stock v6 sounds like shit.
Twin Turbo
Old February 18th, 2011, 11:47 PM   #18
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
What happen with your car??
I don't even remember what cam you were running?
Old February 19th, 2011, 02:02 PM   #19
9986paulk's Avatar
1999 Mustang V6
always seemed like it had a miss and erratic running/starting. We couldn't get the AFR to be steady at all and always had bank-to-bank issues. One would always be pegged lean and the other pegged rich. Took it out and all problems went away. And we did troubleshooting for everything possible, other than the timing mark being off on the cam or some grind error, whatever the odds of that are. It would even make decent numbers sometimes, but always broke up up top and had erratic misses.
And it was a comp cam 212/218 110 lsa .545 lift
Twin Turbo
Old February 21st, 2011, 10:58 PM   #20
2004,1994,1967
14.37 @ 96
wtf ?
227whp N/A V6
Threads Similar to: Possible Cam problems HELP?!?!?
new with temp problems and trans problems 89Bullitt 2.3 Mustangs 4 September 18th, 2010 03:14 PM
problems freebird 99-04 21 April 16th, 2010 09:39 PM
IAC problems?? NEED HELP!! 96trplblkgt 96-98 23 January 25th, 2009 02:36 PM
my problems since Stang187 V6 Mustangs 9 January 19th, 2009 08:59 PM
some little problems XENerd 5.0 Mustangs 6 March 28th, 2007 07:05 AM
