2002 Mustang V6
Car Shakes in Idle, runs heavy in low rpm's
Ok, so i just woke up and went to start my car, it doesnt feel right.. When I let it idle, it shakes pretty bad.. it feels like im in a supped up Muscle car.. when i rev it up to about 2k RPM's it goes away and is smoother.. It also smells like something electical is burning.. I have no idea what is wrong with it. I checked the oil and everything else everything seems to be normal. There is no lights on my dash either.. please help
2002 Mustang V6, GT Rims, Cold Air intake, Blue LED interior.
1999 Convertible V6
Have you checked your plugs? I recently changed mine and smelled an electrical type odor. It went away, but if you changed them in the recent past one may not be firing/connect just right. Just a thought...
1999 Convertible V6
I also just ran seafoam through my system and have noticed a considerable differencen in terms of smoothness and performance. May be worth a try for under $10 and less then 30 minutes of your time.
2002 Mustang V6
I haven't changed the plugs no, That could be a problem, and Whats this Seafoam stuff?
I called my Step dad who was a mechanic a while back, and he said that if water got into any of the connections or wires, that it could be screwing it up, He said to spray WD40 or silicon grease on it, and it should fix it. I did that, and it helped a little, the car still stutters a little when its idling, but no smell. ( just the oil i spilled on the headers that i couldn't wipe off )
Resident badass
Dont even look at the plugs. Check for a vacuum leak. Look at all the vacuum hoses coming off your intake manifold. There might be a vacuum diagram under the hood but I can't remember if our car has one.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
1996 Mustang 3.8
![]() iTrader: 1 reviews
I had the same problem, just cleaned my iac and maf today and it runs smooth as ever
Ever see a lion limber up before it takes down a gazelle?
Mods: ProChamber & Mac Flowpaths 8.8 rear w/ 3.55 gears WTB Mac Tail Pipes PM ME |
2002 Mustang V6
Yeah, Im going to check it tomorrow. I just got home from work and its pissing me off.. whenever i slowly step on the gas it like thuds. So i have to go fast and keep the RPM's up
2000 m112'd 3.8
had the same problem the other week turned out it was the plug on the coil came loose took it off sprayed some cleaner let it dry and it worked fine
Resident badass
Vacuum leak..
2002 Mustang V6
Im going to check everything, And look for a Vacuum leak. Let you guys know.
2002 Mustang V6
AHHHA! I found the culprit.. Dead spark plug. I grabbed some 20k Volt Gloves, and started pulling the plug wires from the Ignition Coil. 1 was great, 2 was great, woooah 3 was dead, and 4 was dying as well.. Solved the problem.. Now I just need to Change them all out
gahh. Makes sense though.. its got ~100k miles, and I doubt the last owner ever had them changed, so I guess I have to do it. Thanks for all the help guys
2002 Mustang V6
Errm, One last thing. Anyone know what type of Spark plug it is?
14.37 @ 96
20k volt gloves ? lol
Just go to your local auto store. They can get you a basic brand if you dont want anything special. Just have them look it up |
Resident badass
Motor craft.
95ish5.0
2002 Mustang V6
I meant like code wise, i got them. And changed my plugs.. only to find.. its my Ignition Coil.. UGH.. So now i get to replace that..
2002 Mustang V6
And yeah dont laugh at my huge 3inch thick rubber gloves. Dont Wana electrocute myself
Resident badass
Lol. It's just high volts. Almost no amps. It will just hurt. Lol
2002 Mustang V6
I know, but I don't even want to go there.. lol
Threads Similar to: Car Shakes in Idle, runs heavy in low rpm's
| 68 302 shakes badly at idle after T5 swap | tevans720 | 5.0 Mustangs | 10 | May 14th, 2010 12:00 PM |
| Motor shakes a lot at idle | Mustang03 | 99-04 | 42 | March 7th, 2010 11:11 AM |
| Engine shakes at high idle RPM's | Phinney | V6 Mustangs | 10 | April 17th, 2009 04:48 PM |
| Idle Rpm's | 96GtGoodz | 96-98 | 19 | December 4th, 2007 11:15 PM |
| 95 GT rpm's fluctuates at idle | Muchavio | 94-95 | 1 | February 8th, 2007 10:49 PM |
