3.8L Head Bolt Torque
Old April 23rd, 2007, 02:01 AM   #1
Cosworth is on a distinguished road
My manual shows a final torque sequence for my '01 V6 Mustang to be "rotate an additional 180 degrees". When I try to perform the final step it really seems like the bolts are going to snap off. Should these bolts be replaced prior to torqueing them down? I am reusing the bolts from the original engine.
Old April 23rd, 2007, 02:22 AM   #2
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
i heard that it was only 90 degrees past the final torque setting... if you fear the bolts breaking then go ahead and get new bolts... cuz a broken bolt in the block will suck so hard
uhh yea i was told only 90 degrees past
Old April 23rd, 2007, 03:44 AM   #3
singe is on a distinguished road
Yeah man...get new bolts...there not supposed to be re-used.
Old April 23rd, 2007, 01:04 PM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
For a 99 Mustang it is 180 degrees and I believe that applies to later engines as well. I believe it was 90 degrees for earlier mustangs.
Yes the head bolts should be replaced. They are torque to yield type bolts. Since you loosen each bolt one at a time, I believe you could replace each one at the same time. Of course if you loosen them all at once you have to replace the head gasket.
The idea of torque to yield bolts is that you stretch them into a non elastic region where the torque remains constant as the bolt is tightened further. The engineers think this is more accurate than measuring torque.
Hope this helps.
Old April 23rd, 2007, 02:21 PM   #5
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
it is 180 degrees there is a torque routine you should really purchase a Haynes Manuel because it tells you all of this.... and there is a special posses in torquing the head bolts on your engine which requires u to loosen the bolts one at a time again and then re torque and stretch it with a 180 turn.
Old April 23rd, 2007, 04:02 PM   #6
Jug...I already have the manual, that's why I was asking the question.
Stephen...Thanks for the info. This is my first experience with "torque to yield bolts". I'll get new bolts and replace them one at a time. I'll be working on the car again Thursday. I'll let you know what happens.
Old April 23rd, 2007, 04:05 PM   #7
Juggalo_X's Avatar
14+@Slow
k dude 180 is correct tho man... they are stretch bolts you torque to speck then stretch
Threads Similar to: 3.8L Head Bolt Torque
Head bolt seeping antifreeze demononwheels 5.0 Mustangs 23 September 30th, 2007 09:51 PM
Head Bolt Headache Buttaz V6 Mustangs 14 August 2nd, 2007 09:06 AM
i6 Head Bolt Torque tnknepp Classic Mustangs 5 July 30th, 2007 09:21 PM
Re-Torque of Head Bolts? lwhitetrash88l V6 Mustangs 11 April 16th, 2007 02:15 PM
Stubborn Head Bolt lwhitetrash88l V6 Mustangs 4 April 11th, 2007 12:49 PM
