2002 Nitrous Injected V6
12's?
Anyone have a diagram of the ignition wires
The 6 wires electrical wires comming from the coilpack. 4 of them are fine but the 2 at the end I have seemed to not reattach it to anywhere. It has metal connection at the end of the wires im guessing this needs to be grounded?? Dont really know hah
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
2002 Mustang V6
Those 6 wires go to your spark plugs, which go into your motor. I actually JUST changed my plugs and ignition coil a few days ago. There should be 3 plugs on each side of you motor. and by 2 at the end are you talking the side near your firewall? if so those are the ones that attach to the far side of the motor. check them good. And you better hope that those 2 are connected, If not. then your plugs arnt firing, which is bad.. don't wana gas wash your cylinder :p
2002 Mustang V6, GT Rims, Cold Air intake, Blue LED interior.
They do go into your spark plugs as mentioned above and i believe this to be the order:
1, 4, 2, 5 ,3, 6 Number 1 is on the LH side of the car not your left but the cars left. Now do a little research because im going of memory but i believe that to be right. Hoped it helped. |
Threads Similar to: Anyone have a diagram of the ignition wires
| need a vac diagram | 97stangerx | General Tech | 1 | December 4th, 2010 11:41 PM |
| diagram | riddlee josh | V6 Mustangs | 10 | January 10th, 2008 10:10 PM |
| MSD Ignition Or Crane Ignition | jg347stroker | 5.0 Mustangs | 0 | December 2nd, 2007 10:05 PM |
| engine diagram? | mow | 2005 - 2010 | 6 | October 15th, 2007 03:12 PM |
| wiring diagram. | HMUSN | All Other Vehicles | 2 | September 23rd, 2007 10:37 PM |
