Brake question
Old February 20th, 2011, 11:03 AM   #1
GreenDragon96's Avatar
1996 Mustang V6
GreenDragon96 is an unknown quantity at this point
Brake question
So i'm changing my brake pads and I started last night, this my first time doing them and I got the 2 bolts off the caliper and took the caliper off but realize i don't have the tool to push the piston back into the caliper so I put it back together and went and got it now I think i got of the screws that holds the caliper (13mm bolt) stuck i'm really hard and it's not coming lose what do i do?????
Old February 20th, 2011, 04:44 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Start out by hitting the bolts with some PB Blaster (comes in a spray can). That shit works wonders for loosening up stuck bolts. If that doesn't work, try using a longer wrench/ratchet or sticking a piece of pipe over the wrench/ratchet (that is longer) and use it for leverage. The bigger the wrench/ratchet, the more power and leverage you have.
My Hubpages
Hey.. r u really a tranny??
Old February 20th, 2011, 06:34 PM   #3
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
How tight did you put them on at lol. Do snap the bolt
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old February 20th, 2011, 08:24 PM   #4
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Where the bold goes brake into the slide pin, put an open end wrench on it. I think its about a 1/2" I forgot what it is in mm.
271rwhp N/A V6
Suck it.
Old February 20th, 2011, 09:54 PM   #5
mcqueen's Avatar
Just a note on this to the OP, make sure you're twisting it the right way. I've snapped a bolt because I was standing opposite of the bolt and twisting it left, which was technically right if I had the head of the bolt facing me. Dumb mistake
My Hubpages
Old February 20th, 2011, 10:15 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Which side did you start on before you realized that you did not have a brake tool? Drivers or passengers?
Old February 21st, 2011, 12:14 AM   #7
1996 Mustang V6
Yeah iknow im turning it the right way....and idid spray some PB blaster on their let it sit for 30minutes turned it a little bit but i had to go to work....i just got home and sprayed some more pb blaster and i'll let that sit over night and mess with it in the morning
Old February 21st, 2011, 01:31 AM   #8
mcqueen's Avatar
Over night? 30 minutes is quite a while imo. I usually spray it on a bolt and give it maybe 5 minutes while I remove other bolts in the area.
My Hubpages
Old February 21st, 2011, 11:52 AM   #9
1996 Mustang V6
i started with the rear passenger side it's the top bolt on the caliper im suppose to twist left correct?
Old February 21st, 2011, 12:17 PM   #10
mcqueen's Avatar
If you're facing the rotor, I believe you should be twisting to the right. It's reversed because you're on the opposite side of the bolt
My Hubpages
Old February 21st, 2011, 03:06 PM   #11
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
271rwhp N/A V6
Suck it.
Old February 21st, 2011, 04:03 PM   #12
1996 Mustang V6
ya igot it off now and pads changed thanks guys sorry bout that
Threads Similar to: Brake question
ss brake brake pads and rotor question... 03gtfirered 99-04 4 November 22nd, 2009 11:54 PM
Brake (ABS) Question... An82Mustang 99-04 8 September 30th, 2009 08:10 AM
brake Question 95BlackStang 94-95 4 May 30th, 2009 09:25 PM
Brake question? MustanG_guy17 V6 Mustangs 14 July 27th, 2007 12:33 PM
Brake Question WVSNS& 5.0 Mustangs 2 April 2nd, 2006 12:34 PM
