dash lights dont come on :(
I was in the parking lot waiting for my girlfriend. She got there so a turned on my lights and I heard a little tick. I blew a fuse so I decided to replace it but i tried it again and it did the same thing. The highbeam lights and everything else work fine, it's just the speedometer, tachometer, and te other 4 gauges. And I replaced the light switch too so it's not that
Please help I am so stumped!!!!! Any help would be appreciated!!!!!!!
2000 Silver Mustang V6 5 Speed |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Bad ground?
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
1999 Mustang V6
yea check your wiring. if wires got messed up and it draws too many amps ittl continue to blow the fuse
MM's Database Error
I bet it blows out your rear lights too. It's a short in there somewhere. I've had the same issue. What do you have hooked up that you have added?
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
#5 | |
1 Wheel Peel
2000 Mustang 393w
Took 3 shops to find it though
#6 | |
MM's Database Error
It would be good if he can just tell us what he has added.
You said you blew the fuse twice right? If thats the case then it does sound like you have a short somewhere that is just going to keep blowing it. If you own a continuity tester and dont mind folowing your wire for a bit then i suggest doing that. No promises that its even the problem but thats just what i would do.
I'd say get a wiring diagram & get into that dash to find that short. I have the same problem after messing around with sub amp wiring without disconnecting the neg battery terminal 1st. All exterior ligts work but dash + a/c controls are dark. My stang goes through fuses the same way too. You're gonna have to find the short. A local Ford dealership estimated $300-$500 to find/fix it.
Threads Similar to: dash lights dont come on :(
| dash lights dont work :( | austinknoll | 99-04 | 1 | February 21st, 2011 10:08 PM |
| LED dash lights!!! | PurpleStang96 | 96-98 | 62 | December 2nd, 2010 04:48 PM |
| Dash Lights | JBooks | V6 Mustangs | 4 | June 7th, 2010 01:27 PM |
| dim dash lights on 67 | pritchr1 | Classic Mustangs | 7 | June 15th, 2008 02:09 PM |
| dash lights... | 92hatchback | 5.0 Mustangs | 3 | May 26th, 2008 10:11 PM |
