problem
Old February 23rd, 2011, 10:33 PM   #1
Goliathjz is on a distinguished road
problem
I have a 98 v6 mustang. It runs fine, but when i try to start it sometimes it takes a few tries (pumping accelerator helps i think)
Sometimes on startup it will run rich..and kind of shake the car...but when it gets started for a minute or two it runs fine. Somebody told me this could be a misfire in the engine?
I have 143k miles.....runs fine after that first minute (only happens sometimes)
What do you guys think?
And is a misfire harmful?
Old February 23rd, 2011, 10:47 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Do you get any CELs when this happens? Misfires often set off a flashing CEL.
When you try to turn it over, is the starter cranking?
Have you ever changed the fuel filter?
My Hubpages
Hey.. r u really a tranny??
Old February 24th, 2011, 01:04 AM   #3
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
Do you hear the fuel pump prime up before you start it? Put it key in the ignition and turn it (not all the way to start it) just turn on the accessories and listen for the fuel pump to prime, you will hear it somewhere behind you. It's actually a pretty noticeable noise.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old February 24th, 2011, 08:45 AM   #4
CELS? the starter cranks yes. It just doesnt fully start, I get the theft light and other light when it turns on then they go off. Other then that its good, I havnt changed the fuel filter. And I will check if i hear it today.
Old February 24th, 2011, 08:51 AM   #5
craigdavey's Avatar
craigdavey is on a distinguished road
CEL's = Check Engine Light's
Definately check the starter.
2004 3.9L Vert (sold)
Old February 24th, 2011, 09:02 AM   #6
Alright I'll check that today, but does that explain the kind of shaking for the first minute?
During this minute, it idles very low at times and shakes.
Old February 24th, 2011, 10:28 AM   #7
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Sounds like the ECT or IAT are not reading correctly. Hook up a scan too and say what they read when the engine is cold vs. when it is at op temp idling. Cold, the sensors should read the same, and warm the ECT will read a higher temp. But at cold they should read outside temp.
271rwhp N/A V6
Suck it.
Old February 24th, 2011, 10:49 AM   #8
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
This is a fuel injected vehicle, pumping the accelerator shouldn't effect startup like it would with a carb.
The OP said that the engine cranks when he attempts to start it; the starter is doing its job.
My money is on the ECT.
To the OP, you never said whether or not you've gotten any CEL's. Also, try starting the car with the accelerator just barely depressed. How does it run in that situation?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old February 24th, 2011, 12:50 PM   #9
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I don't even know what to say.
271rwhp N/A V6
Suck it.
Old February 24th, 2011, 02:01 PM   #10
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
271rwhp N/A V6
Suck it.
Old February 24th, 2011, 03:32 PM   #11
craigdavey's Avatar
What does CEL stand for?
Old February 24th, 2011, 07:03 PM   #12
To the OP, you never said whether or not you've gotten any CEL's. Also, try starting the car with the accelerator just barely depressed. How does it run in that situation?[/QUOTE]
it still has to have the key turned a few times before it fires all the way over
Old February 24th, 2011, 09:57 PM   #13
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
try changing plugs and wires. possibly coil too
Old February 24th, 2011, 11:39 PM   #14
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
CEL - Check Engine Light
The proper term though is MIL - Malfunction indicator lamp/light.
271rwhp N/A V6
Suck it.
Old February 24th, 2011, 11:41 PM   #15
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I wouldn't change anything until you verify equipment that is not working properly. Plugs wires and coil pack is not related to the problem anyways.
271rwhp N/A V6
Suck it.
Old February 25th, 2011, 08:39 AM   #16
Tang Stang's Avatar
As in the key has to be cycled between "ON" and "OFF" a few times, or are you saying it takes a few starting attempts to get the engine to fire? You didn't answer my question as to how it runs once it has started (with the accelerator just barely depressed). You also still haven't said if you've received any CEL's.
We need more info here.
Old February 26th, 2011, 12:45 PM   #17
a few attempts to get it to fire. and as long as the idle is high, it only shakes when it goes very low when it first starts. This does not happen EVERY time. Only certain times. No CEL's
Threads Similar to: problem
misfire problem, probelms, probably a problem? rewadferger 96-98 5 September 13th, 2010 12:17 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
AC problem = Tune problem? SKRAPR 2005 - 2010 11 May 16th, 2009 12:29 AM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
