VSS sending unit
Old February 25th, 2011, 06:22 PM   #1
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
VSS sending unit
So im recalibrating the speedo and want to now if the vss sending unit is the same for the v6 as it is for the 4.6 2v? All the wires match so im wondering if I can tap into the wires?
Also I ask for the vss only, im not buying a $370 tuner for a part that im not going to need since this is the last thing for this car.
Im going to do it in an hour or two.
Formerly, AhobosCheese and Cheddars.
Old February 25th, 2011, 08:13 PM   #2
BlueScreaM's Avatar
2012@lightspeed
I guess ill find out.
Old February 25th, 2011, 11:21 PM   #3
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Same. You have a T5 and so do the GTs. Same sensor, same wires. All good.
271rwhp N/A V6
Suck it.
Old February 25th, 2011, 11:49 PM   #4
BlueScreaM's Avatar
2012@lightspeed
Didnt work
My speedometer isnt working attached the green/white wire back together and works fine but the speed is still off...
Going to check currents tomorrow, at lease it only off by an even 10 mph.
Old February 26th, 2011, 12:05 AM   #5
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Manual right?
271rwhp N/A V6
Suck it.
Old February 26th, 2011, 12:20 AM   #6
BlueScreaM's Avatar
2012@lightspeed
Manual right?
No auto but the diagram is the same for both trannys. Idk if the ground source was bad or the on key current I taped into.
Unless my calculations are off in the speedcal. 3.27/4.10=.80 right?
Old February 26th, 2011, 12:54 AM   #7
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Calc is right. You have a DMM?
271rwhp N/A V6
Suck it.
Old February 27th, 2011, 10:55 AM   #8
BlueScreaM's Avatar
2012@lightspeed
Ive checked the wires and the speedometer is going crazy. IDk what to do about it.
Old March 17th, 2011, 07:16 PM   #9
BlueScreaM's Avatar
2012@lightspeed
*update*
After much frustration I refunded the speedcal tool back to AM and have a SCT on the way... I didnt want to put more money in my car but I have no choice now.
@Red: Ford said the problem is my radio, its messing up the speedcal.
Verdict: speedcal is a waste. But AM customer service is great!
Old March 18th, 2011, 01:11 AM   #10
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Speedcal was always a waste. It's basically an expensive set of speedo gears.
271rwhp N/A V6
Suck it.
Threads Similar to: VSS sending unit
Fuel Sending unit Itkix 94-95 8 December 4th, 2009 01:01 PM
bad fuel sending unit 707Stang 2005 - 2010 V6 3 April 23rd, 2009 06:33 PM
temp sending unit egghead 96-98 2 February 26th, 2008 09:42 PM
Oil Sending Unit? silver99gt 99-04 3 January 10th, 2008 12:44 AM
Fuel Sending Unit terribleonexx88 5.0 Mustangs 6 November 1st, 2006 10:29 PM
