Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
8.8 rear end
Couldn't I use this with my car? what else would I need? I'd order 3.73 gears, do i need a tlok?
http://www.americanmuscle.com/moser-...axle-9904.html |
'00 V6 Procharged Mustang
Uhh.. The entire 8.8 rear end pretty much? Axles are only a small part of a rear end. You'd also need a different diff to use 31 spline axles in a 7.5 and I believe the same is true for a 8.8.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
yeah thats what I thought, im just gonna throw 3.73 and tlok on my stock 7.5? or would it make more sense to keep searchiing for an 8.8 rear end, I've been searching craigslist for months, hard to find anywhere close to me.
Unless you really plan on making like 300hp+ and using really sticky tires there's no need to go to 8.8.
14.37 @ 96
Yes an 8.8 works ... I have 1 with 3.73s as well ...
Ill need it soon ![]() and btw ... your 7.5 can handle 300+hp really what matters is the torque you put on it ... it can handle 1000hp if you drive it right ... but who does that ??? really ?? lol 8.8 = more wieght. << some say bad, but hey, more weight equals more traction ![]() but a 7.5+tlok+bearing kit+gears+tuner = happy in your case. so you can go ahead and search any of that you dont know. 7.5-8.8 million threads out on it already :p |
Craigslist is a better place to search for a used 8.8 than ebay but I'd recommend checking out your local Pick'n'Pull or auto salvage yard. There are lots of totalled GTs out there (from folks who didn't know how to drive em) & 8.8 rears are a dime-a-dozen. They're a gold mine when it comes to pulling servicable parts + they're relatively inexpensive!
Make sure you check for rust & any visible physical damage. I would take everything between the rotors (to include the set of axle dampers if they're present).
2000 Mustang V6 Vert
Look at the lugs too and too! see if the ABS sensors are intact if the rear end has ABS. Sometimes you get lucky (like i did) and get a rear nice 8.8 for cheap.
![]() 2000 Mustang Convertible: BBK CAI True dual: H-Pipe and Flowmaster 40's SCT SF3/X3 Tuner 8.8 Rear End 4.10s FRPP |
14.37 @ 96
I paid 125$ to get an 8.8 and have gears installed and put into my car.
Then I paid whatever a 3.73+bearings rebuild+ Tlok rebuild kit cost on my own. Then how ever much AMSoil for my diff costs |
14.37 @ 96
And thay arent a dime a dozen on my CL usually 250-350 as is ...
mustangmike! is right they can get pricy depending where youn live. I got mine for $400 up here in NY which is a good price for one with 50k on it. Installation prices from shops vary as well.. Ive been doing all the work myself and its alot easier than it sounds. Taking your time is key
Threads Similar to: 8.8 rear end
| Pics of 275 rear tires (rear view please) | WhiteMamba | 5.0 Mustangs | 35 | October 15th, 2010 02:03 PM |
| Rear seat delete, Legal to remove rear seatbelts? | epwchill | 94-95 | 12 | June 6th, 2009 10:28 PM |
| rear disk brakes and rear end | extropy | Classic Mustangs | 3 | August 11th, 2008 06:41 PM |
| removing rear seat and rear moulding? | 07 STROKER | 2005 - 2010 | 11 | April 26th, 2008 04:17 PM |
