#61 |
1996 ford mustang
ok ill give justin a call to i/c i need to get the windstar intake right ?
yes it is a v-1 and compression is 8.1 i lowered it |
#62 |
[8MINUS2]
Not needed, but it helps.
#63 |
1996 ford mustang
would you happen to have any pics one i/c ? i think it would be kinda a pain to do with out the other intake .... or if you no wjat parts i would need to order
thanks again guys 4 the help |
#64 |
2003 mustang
7.48x1.56=11.67
Yeah, go to 3.8mustang.com and look up "skatefreak" and "jpk4l3", both of their setups had intercooled vortechs. You'll need to be retuned if you intercool it because you'll need to switch from draw through to blow through.
Another option would be to check out the andersonfordmotorsport mr freeze kit. It's a mechanical methanol injection setup. If I were non intercooled, I'd run it. btw...I made 300/308 stock with 10psi on a very conserative tune. I'd say your tune is off pretty bad to make what you did with all those mods. Or you have some other mechanical issue. Also, I made 370/372 with 13psi and a cam swap on stock heads and intakes, and my cam is smaller than the one your running. I'd bet anything your tune is off.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
#65 | |
[8MINUS2]
IMO, the car needs more boost, and prob a bit more timing, and lean out the a/f just a bit. Do you know if the lower intake still has IMRC's? Pics of the engine bay would be nice.
#66 |
1996 ford mustang
IMRC's are deleted i can get you a pic of the engine bay
#67 |
[8MINUS2]
go for it.
#68 |
Honestly I think the two things that are killing your E.T.'s the most (from the info provided thus far) is the low CR and the stock TC. I wish you had your timeslip so we could see the short times. With the stock stall and the power curve that your dyno sheet shows, the 60' times were probably pretty terrible. I agree with ESG on the suggestions of more boost and leaner A/F, and I'd add a higher stall TC to that as well.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
#69 |
Resident badass
Stock stall is good for.. Stock. Anything more and it's a good paperweight.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
#70 |
2001 Mustang GT
12.33@111.23mph
![]() iTrader: 3 reviews
my old 96 v6 auto ran a 16.2 with no launch!!!!! just smashing the gas pedal at the light. It had cai,udpulley,tune,4.10's,alum driveshaft and just a catback exhaust. Also this was the good ol shitty singleport aswell. So I can tell you for a fact somethings wrong with your car
![]() 2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution 1996 Civic DX - my dd |
#71 |
[8MINUS2]
there are plenty stock stall cars that've done better than 15s with 300hp!
#72 |
2000 Mustang
slow@slow
as long as were talking about stalls, how exactly do they work?
#73 |
Agreed. However, with the power curve his dyno graph shows, he's not making much hp/tq until at least 4K. With a stock stall and that power curve, I'm sure the 60' times are suffering. The chosen CR really should have been closer to 9:1 since we're working with a centrifugal and not a PD SC here.
Threads Similar to: went to the track ....... angry on times Help!
| New best times at the track!!! | black05stxjt | 2005 - 2010 | 5 | March 23rd, 2008 04:26 PM |
| New Track times | kennyGT | 99-04 | 15 | February 11th, 2008 03:53 PM |
| New Best Track Times from MIR | 2k05gt | Drag | 13 | November 2nd, 2007 01:43 PM |
| New track times | auburntiger7231 | Drag | 8 | October 26th, 2007 03:44 PM |
| New track times!!! | 2BFEARD | 2005 - 2010 | 10 | April 8th, 2007 11:41 PM |
