1996 ford mustang
went to the track ....... angry on times Help!
so over the week end i finally brought the car to the 1/4 mile track and im pretty upset on what it ran so i need some help ...... here are the mods
split port swap ported and polished [intakes and heads] comp cams valve springs and retainers head studs arp head gaskets 3 layer Forged internals [from ssm] 8.1 compression bored .30 over Oil pan from supercoupe motor with custom baffles welded in and extended pickup tube valve covers bbk Spark plugs NGK tr6 [colder] cam .550 lift [compcams] vortech 12 psi detriot trutrack diff motive gear 3.73s sct chip/ custom tuned by ramseys performance walbo 255 fuel pump Vortech 155 inline pump injectors 42 pound Maf svt lightning exhaust x-pipe flowmaster american thunder exhaust ford racing lowering springs 2 inch drop tokico shocks ford racing sway bars Built tranny – 4r70w stock stall for now it ran a 15.5 at 96 mph i dont get it ...... the car on the dyno made 305hp 290tq and even thats really low i think 4 what mods are in the car let me no what you guys think .... think its the tune ??? |
i think you need to sell the car to a better driver...or get some seat time
MM's Database Error
driver mod
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
!FACEPLATED!
ditch the front sway bar, get better rear tires, and just practice.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2004 Mach 1 Mustang S/C
Formerly 01silversixer
2001 V6
15.47@89.57
Driver mod + tires imo.
What was your 60' ? |
Resident badass
Look at my time... Nearly stock with a bent rod...
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
1996 ford mustang
how do you Practice with a auto ? my reaction time was on the money and i dont think i spun the tires ...... think its time to go v8
1996 ford mustang
im just pissed if its not one thing its another i dont get it
Driver mod. Is it a 5 speed
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
1996 ford mustang
nope auto ..... stock stall upgraded clutchs
Needs 2 cylinder bolt on
'03 Mustang V6
It's a six so what do you expect?
full break and about 20% gas. on green, about 90% gas (so no spinning) once rolling, FT. That should help. As 6er said, Slamming the gas on green is a no go to times.
Formally Ur PaNic
2002 Mustang GT 4.6L
The reason it's wise not to go WOT on green is because the automatic computer shifts the car into a higher gear, reducing low end torque you'd otherwise get from letting it go through the gears naturally.
![]() 2002 Ford Mustang 4.6 GT Coupe 4-spd Awesomatic - B&M Hammer - Procharger P1sc - 3 Core Intercooler - SCT Xcal3 - SSS Terminators DGR / Dave Guy Tuned 354 rwhp / 365 rwtq |
1996 ford mustang
ok ill try that thanks ...... even if i wanted to spin the tires i dont think i can isnt that a problem thats why i think somthing is wrong in the tune idk
Formally Ur PaNic
lol at least I try and help
Resident badass
Sounds like you should be running 12s pretty easy. I would take it to another tuner and get my money back..
Moderator
2012 300a gt auto
12.10@116
a huge problem for you is the stock converter, most likely close to a full second waisted there.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
Threads Similar to: went to the track ....... angry on times Help!
| New best times at the track!!! | black05stxjt | 2005 - 2010 | 5 | March 23rd, 2008 04:26 PM |
| New Track times | kennyGT | 99-04 | 15 | February 11th, 2008 03:53 PM |
| New Best Track Times from MIR | 2k05gt | Drag | 13 | November 2nd, 2007 01:43 PM |
| New track times | auburntiger7231 | Drag | 8 | October 26th, 2007 03:44 PM |
| New track times!!! | 2BFEARD | 2005 - 2010 | 10 | April 8th, 2007 11:41 PM |
