Car Trouble..Help Please
Old March 1st, 2011, 07:09 PM   #1
mimi305miami's Avatar
1997 Mustang
mimi305miami is on a distinguished road
Send a message via AIM to mimi305miami Send a message via MSN to mimi305miami Send a message via Yahoo to mimi305miami Send a message via Skype™ to mimi305miami
1st of all...if i didnt post this in the right place or in the right way im sorry im still trying to figure this all out....feel free to correct me
Ok...lets c how i can describe everything that is happening
i have a 97 mustang 3.8l v6
1. car squeaks from time to time ... front shocks need to be replaced but not sure if that's what's causing the squeaking
2. when decelerating or at a complete stop the car will vibrate....was told this is caused by a bad o2 sensor (bank1 sensor1) and some cable behind the engine that has something to do with the o2 sensor that needs replacing cause it's torn
3. SUPPOSEDLY i have an oil leak and i need to replace the valve covers
i don't know how much truth these things i've been told by several mechanics hold BUT 1 mechanic tells me 1 thing and another tells me another. im sort of just looking for the truth lol
i know for sure my shocks and the o2 sensor and cable need replacing....all other issues im totally lost.....
please help...thanks
Old March 25th, 2011, 11:48 PM   #2
1997 F-250, 1978 F-150
est14.6@96
FordmanT is on a distinguished road
1. Squeaks is not a good enough definition sorry, but if you've been told that you need shocks then that is a good place to start! Technically speaking you should replace them every 60k or so......
2. The vibration sounds like either it's being caused by a misfire or to high an idle, could be an O2 sensor, which comes with the new 'cable' or harness that they are likely referring to.
3. Oil leak, do you notice a loss of oil? Or a spot of oil under your car? Or a burning smell while driving or after? If no to all of these then you probably don't need to address this yet, up to you. You shouldn't need new valve covers, just valve cover gaskets.
Hope this helps
4SALE:misc 04 cobra: SVT 4vHeads port/polish/deck @SVT, CenterForce dual friction clutch, 4lb crankpulley, Steeda Foxbody strut tower brace, Accufab Intake tube PM 4 info
Old March 26th, 2011, 10:19 AM   #3
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Do you have a check engine light on? If so get your codes retrieved and post the codes up here.
Old March 26th, 2011, 11:11 AM   #4
Super Spud
MeMz's Avatar
2002 Camaro SS
MeMz has a spectacular aura aboutMeMz has a spectacular aura about
Does the vibration happen when your hitting the breaks and off the brakes? If your leaking oil, than be sure to make sure your oil filter is tight, drain cap is tight, and just double check everything in your engine bay. Make sure your not leaking oil from around any spark plugs either
2002 Camaro SS M6 Hardtop LPM #6157
MM+Cleavage Club Member #9
Originally Posted by G.T. Rags View Post
i'm like fucking herpes, you ain't ever getting rid of me
I'm so cheap I could suck Lincoln off of a penny beechez.
Old March 26th, 2011, 01:21 PM   #5
2000 v6 mustang
1slowv6 will become famous soon enough
+1 on the burning smell... if its coming out of your valve covers (or spark plugs?) then it would hit the manifold and smell like SHeeTT but then again mechanics like to quote one thing when they know its another so they can get you in their shop thus giving them the upper hand.
take some pics of the leak. in my case i think ive narrowed my oil leak to the rear main seal thanks to the guys on MM. if the leak is coming from what looks like where the engine meets up with the tranny its probably a cracked or worn rear main seal...
as for the vibrations cant help ya there
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old March 26th, 2011, 02:41 PM   #6
Dancing Naked In The Rain
mcqueen's Avatar
Hope this helps
I agree with all of this. For #2, vibrations can also be caused by a low idle. If the idle drops low enough the whole car will shake.
My Hubpages
Hey.. r u really a tranny??
Old March 30th, 2011, 10:31 PM   #7
est14.6@96
Good point, forget to mention the simple things sometimes that just come with experience
Threads Similar to: Car Trouble..Help Please
having some trouble help 96sickstang 96-98 8 December 10th, 2009 10:33 PM
Having trouble with IE. Dansby The Clubhouse 13 November 26th, 2009 02:06 PM
would i get in trouble for this? graystang01 The Clubhouse 43 July 4th, 2009 12:39 AM
Trouble Already ryans88gt 5.0 Mustangs 14 April 12th, 2008 02:35 AM
C4 TROUBLE! sn-95aac 5.0 Mustangs 5 July 13th, 2007 06:01 PM
