Is this normal??
Old March 3rd, 2011, 06:36 PM   #1
1997 Mustang v6 manual
Dfeeds is on a distinguished road
Is this normal??
So I'm in the process of dropping the transmission. I go to remove the drive shaft only to find that it still is spinning freely. I double check to make sure the e-brake is on and it is. Long story short, the e-brake is only stopping the right rear wheel from spinning, not the left. Is this normal because of the open differential or do I have an issue here?
If it is an issue I guess that would explain why I found my car in the middle of the road one day after leaving it in my driveway and not in gear...
Old March 3rd, 2011, 07:26 PM   #2
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
It's normal for the differential to allow that but it's not normal for your brakes to allow that. E-brakes should be equally functional on both wheels. You'll want to investigate the brake that isn't stopping correctly.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old March 3rd, 2011, 07:31 PM   #3
Yeah that's what I had suspected. Looks like what is an already tedious job just became that much more so.
Seeing as I already drained the trans fluid and am mid process, is there a way to prevent the drive shaft from spinning? I would assume putting it in gear but I'm not sure if I could possibly damage something by applying excessive force to remove the bolts.
Old March 3rd, 2011, 07:36 PM   #4
I'd try to just jam your normal brakes on if possible(assuming that stops that side). Power seats + 2x4 + brake pedal = stopped.
Old March 7th, 2011, 03:45 AM   #5
Modded V6
Stang6899 is on a distinguished road
Put it in 1st gear
1999 e46 328i BMW - Daily Driver
2001 SVT Cobra - Project
1995 v6 vert - SOLD
1996 v6 vert - SOLD
1995 v6 vert #2 - SOLD
1995 GT - SOLD
1997 v6 coupe - Parting
Old March 7th, 2011, 09:19 AM   #6
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
looks like you need to replace one or both rear calipers.
Old March 7th, 2011, 10:10 AM   #7
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Check the ebrake cables before u start replacin calipers. They might have stretched. Puttin the car in gear will help you get the job done.
Threads Similar to: Is this normal??
Is it normal? mcqueen V6 Mustangs 830 May 20th, 2010 03:24 AM
Is this normal? carlos General Tech 1 January 12th, 2009 10:17 AM
Normal? Onemanzu The Clubhouse 8 January 19th, 2008 03:23 PM
Is this normal? scxc15 V6 Mustangs 10 January 13th, 2008 01:46 AM
is it normal Blk01ponyGT 99-04 14 January 12th, 2008 03:30 PM
