'00 Mustang V6
Slow but looks nice :p
Ball joints??
It's been a while...
My car makes a real weird knock sound whenever I steer at real slow speeds. I'm assuming my ball joints have gotten worser. How hard are they to install? Also, where could I get a good deal on them? Maybe I'll even try to post a vid of the sound tomorrow so someone on here can help me diagnose the problem. It just really doesn't feel safe to drive, that's how bad it sounds inside the car. Kinda feels like the wheels slip a bit when turning. Help... please??
![]() Build Thread Parts For Sale Mods: 01 Cobra Bumper, GT Rear Bumper, Reverse Glow Gauges, Smoked Headlights, Smoked Fogs, Windstar Upper Intake, 8.8 Rear End, Drilled & Slotted front brakes, to be cont'd... |
I'm doing it wrong
04 Grand Cherokee
Bad ball joints squeak like crazy when they are going bad, not a high pitched squeak either its like a low pitched annoyin noise. Closest thing I can compare it to would be the noise of a door opening slowly in a scary movie lol. If they are going bad, don't drive your car. Just bring it to a shop. You don't want them to fail while you are driving. Happened to me while I was driving and my control arm wedged itself into the spokes of my passenger side rim while I was going 30mph, brought me to a dead stop. Now picture that happening while your on the highway, you will most likely flip the car.
Now you can do the install yourself if you have a ball joint press but I heard doing it is a pain. So might as well just go to a shop and have it done, will get done faster with less headaches.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
'00 Mustang V6
Thanks man!
Whenever I decide to park my car, I may take a vid. I'm def trusting my instincts and I'm not gonna drive it. Reason it may be so bad now is because I knew they were going bad, but I have not had any time to get it fixed. Earlier today, passenger wheel rubbed badly on the curb of my driveway and ever since, it sounds terrible!
Better than ONLYaUNCfan's
2012@lightspeed
Raise it up on jack stands and see if the wheel wiggles and makes a noise. That will indicate if there bad.
Formerly, AhobosCheese and Cheddars.
'00 Mustang V6
Thanks dude, will see when the sun rises.
1999 V6 Mustang
For me ball joints have always made a popping or clunking sound. Most noticably when hitting a bump or when turning the wheel. Normally if I suspect bad ball joints while sitting still in a parking lot I'll turn the wheel a little one way and then a little the other, and when I change directions you can it hear it pop. This test will also indicate bad tierod ends, so I'll have someone reach under the car and touch the tierod ends and ball joints when I do this so they can tell me which one they feel popping back and forth.
#7 | |
'00 Mustang V6
'00 Mustang V6
1999 V6 Mustang
It sounds like something is binding up, my joints have always worn out and gotten loose but if the boots were bad water could leak in and start to rust the joint making it tight. It sounds like whatever is making that noise is under pressure and the ball joint is the only thing I can think that would be, and demon 54 seems to have seen them fail this way before.
'00 Mustang V6
Replacing whole lower control arm would be in my favor says the ball joint king
![]() Thank God for good people!
#11 | |
Speed Concepts - M-3075-D - 2003-2004 Cobra Front Lower Control Arms Kit for all 1994-2004 Mustang GT/V6/Bullitt/Mach1/Cobra Hope this helps.
![]() Sig by Tricep |
You can jack up the front end, take a long pry bar under the front wheel and "pry" it up while someone watches the ball joint. If they are loose/ worn you will see the play in them.
Threads Similar to: Ball joints??
| Steeda X2 Ball Joints look really similar to Foxbody Ball Joints... | asiansensation78 | 99-04 | 3 | December 26th, 2010 08:33 AM |
| HELP with Ball joints??? | SLPstell | 2005 - 2010 | 3 | October 30th, 2010 04:18 PM |
| Is it the ball joints? | Mr. Red Pony | V6 Mustangs | 10 | July 26th, 2010 01:56 PM |
| Ball joints? | Spurred Snake | V6 Mustangs | 19 | April 22nd, 2010 04:54 PM |
| X2 ball joints? | 01KnightRiderGT | 99-04 | 2 | March 4th, 2010 07:09 AM |
