Negative effects of a bad battery?
Old March 5th, 2011, 08:31 PM   #1
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
So my car still has the original battery in it and after 10 years it's starting to go downhill fast. It doesn't crank as fast as normal and I get the full gauge sweep upon starting. Now I'll replace the battery soon enough but I'm more wondering are there any negative effects from running it how it is?
Like is my computer resetting each time I start the car? Would it put an extra strain on my alternator? Things like that.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old March 5th, 2011, 09:45 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
As long as the connection to your battery is not broken then your computer is not resetting. The alternator just charges the battery. (in this aspect) You are not really going to hurt anything by using a weak battery. You will end up stranded one day when your car doesn't start when those cca's get low enough. You car doesn't even use the battery after you start the car except to keep the electrical loop. Unless you have a winch or something.
Old March 6th, 2011, 01:12 AM   #3
Well my winch does use quite a bit of battery....
I was just wondering if it'd be constantly trying to charge more than it should or something.
Threads Similar to: Negative effects of a bad battery?
Can spray painting the radiator (behind the grill) cause any negative side effects? Ryan818 2005 - 2010 8 February 2nd, 2011 12:59 PM
Can spray painting the (radiator behind the grill) cause any negative side effects? Ryan818 2005 - 2010 0 February 1st, 2011 06:02 PM
negative camber 8.8 will2045 99-04 2 December 29th, 2010 12:38 PM
Negative Battery Cable from Duralast OcOnnor220 99-04 3 March 11th, 2007 04:21 PM
