My car's been acting up.
Old March 5th, 2011, 09:13 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Ok well my car has been acting up for awhile now.
It cranks over for a long time when it has been sitting over night before starting. It is colder outside too right now in the 20s or so. I have a brand new battery that I put in last year, I cleaned the posts and clamps just incase.
It just seems to me that it cranks and cranks and then like partially starts and then barely fires and will start up. It only happens over night. I was thinking maybe a bad check ball in the fuel pump but that should not matter, I have tried cycling the key twice to prime it and it did the same thing.
Also today I was driving around and it started idling really rough. It felt like a broken motor mount. But when I would give it gas it would run fine. I didn't feel a miss once I put my foot on the gas. And I noticed that when it was idling rought the AF ratio on my wideband would slowly go lean to sometimes 16:1 or more then quickly drop back to rich. I am wondering if I don't have some 02 sensors that are acting up. I just bought a fuel filter it has been at least 2 years since I put one on so I figured I would try that first. It was just too cold tonight to put it on.
What are your guys thoughts? I am hoping it is the fuel filter and that will fix the cranking and the rough idling. It has been feeling doggy too when I mash it to the floor so I hope that is the problem!!! it only has 97k on it.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old March 5th, 2011, 09:15 PM   #2
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
i don't think its the fuel filter.
238rwhp/263rwtq
Drew's Build Thread
Old March 5th, 2011, 09:25 PM   #3
02GreyStallion's Avatar
2002 v6 Mustang
02GreyStallion is on a distinguished road
My thought on the slow start is Plug Wires. My stang did that and then I picked up the MSD wires from AM and it fires right up
- Mac 2.5" with 3 " duals
- AM Cold Air Intake
- Clear Fog Lights
- Mach I Chin Spoiler
- Mach I Grille Delete
- MSD Plug Wires
- New Clutch
- Window Tint (Future)
- Tokico Blues (Cut Springs)
Old March 5th, 2011, 09:37 PM   #4
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Sounds like the coil pack is building excess internal resistance during the cold.
You you have a was to measure electrical resistance?
If so, I'll go more into detail. If not; get one and then I'll go into detail..
271rwhp N/A V6
Suck it.
Old March 5th, 2011, 09:39 PM   #5
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
After re-reading, I think it could be the IAT or ECT sensors are acting up.
271rwhp N/A V6
Suck it.
Old March 5th, 2011, 10:19 PM   #6
Codeman's Avatar
I will have to check coil resistance later. I just went out and sucked it up and put my new fuel filter in at 0 degrees F. HAHA. Well my old one I shook up and poured fuel out and it was full of crap!!! I started my car and it idles much smoother now and the AF ratio looks much better. I will have to wait and see in the morning if it works better. Lets hope.
I replaced plug wires last year but they were some cheap ones.
Old March 5th, 2011, 10:46 PM   #7
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Secondary resistance should be 8k ohm to 14.5k ohm per coil. Mine was getting over 20k ohms of resistance at just below freezing.
271rwhp N/A V6
Suck it.
Threads Similar to: My car's been acting up.
Car's trippin out... Youngin The Clubhouse 12 May 14th, 2009 12:50 AM
car's in the shop Squints 5.0 Mustangs 20 February 5th, 2009 09:34 PM
my car's sputterin when i tap the gas..need help 006leenstang00 Modular Mustangs 3 March 13th, 2007 11:15 AM
Newbie, and our car's pic's!!!!!!! 2BFEARD New Members Introductions 6 February 16th, 2007 11:37 AM
will Fox body LT headers fit our car's? 95oldyeller 94-95 0 February 6th, 2007 10:02 PM
