2004 Mustang Convertible V6 3.8L - "Clicking" on cold engine start
LinkBack (1) Thread Tools
Old March 8th, 2011, 03:11 PM   1 links from elsewhere to this Post. Click to view. #1
kromestatus's Avatar
kromestatus is on a distinguished road
Question
I have a 2004 Mustang convertible 3.8L V6 and for a few months now I have had a kind of clicking noise right when I start up my car or when my engine is cold and it usually lasts about 3-4 minutes then goes away. I have been told 3 different things from 3 different people but they are just assumptions.
1) "There is nothing wrong with your Mustang, they tend to make that noise".... ROFL!!
- Certified mechanic
2) "It could either be your lifter is bad/sticking or there is an exhaust/manifold leak is my guess, but that is definitely not normal"
- Retired Mechanic (Neighbor)
3) "When I was working on your brakes I noticed a crack in your exhaust manifold. I would recommend getting it fixed soon so it doesn't get worse or you could probably pick a used one up at the junkyard for not too expensive"
- Another Certified Mechanic who did my brakes
So I attached a video to youtube and some images to my engine so if anyone has any idea let me know
The sound inst that great but listen really closely around 52-54 seconds and you'll hear the clicking pretty well.
VIDEO
IMAGES
Old March 8th, 2011, 03:15 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
A combo of 1 and 2 is possible. Ticking is a noise that our cars tend to make and I believe the most common cause (internally) is the lifters sticking. Not a huge deal, I believe removing a quart of oil and replacing it with a quart of auto tranny fluid can help lubricate them better.
A 2 and 3 are likely. Our cars are notorious for having cracked exhaust manifolds. When exhaust gases are escaping, they tend to make a ticking noise.
I recommend turning on your car, popping the hood, and listening very carefully to figure out where the noise is coming from. If it's the exhaust manifold, get it welded. If it's the lifters, buy some auto tranny fluid.
My Hubpages
Hey.. r u really a tranny??
Old June 5th, 2011, 12:57 PM   #3
JJH
JJH is on a distinguished road
I have an 04 v6 as well, mine does the same thing but goes away, I haven't had any issues,I just think that's how they idle when started.
Old June 5th, 2011, 03:41 PM   #4
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
On your next oil change add a small container of motorkote to the oil. If its a lifter sticking the Motorkote will lubricate it better than the auto tranny fluid will and will fix it. If its more of a periodic hiss than a tick its a leak in ur passenger side exhaust manifold. have repaired, and install an AC drip line on ur ac system to prevent this from occuring again.
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
Old June 5th, 2011, 06:33 PM   #5
Unavailable's Avatar
2004 Mustang 3.9L
Unavailable is on a distinguished road
Most likely number 3. Happened to my 04 3.9 and just had it repaired a month and a half ago.
Old June 8th, 2011, 10:05 AM   #6
shipwreck_98's Avatar
2001 Mustang 3.8
shipwreck_98 is on a distinguished road
Its the exhaust manifold, the crack is small now and the only way to really see it is if you take it off and inspect it. It will eventually get worse, but it will always sound awful on startup and go away after idleling for a few minutes. Then it will get worse when you step on the gas.
Its an easy fix, new manifolds arent that expensive.
Old June 8th, 2011, 01:00 PM   #7
Jailbait till 2013
whyxitx's Avatar
2001 V6 / 94 Z28-gone
0-60 in -10.3
whyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to behold
Just take it off and weld it up if it's a crack in the manifold. I'm going to warn you that the passenger side manifold is a bitch to get out. Remove the airbox so you have a little bit of room to work with. My mustang also has a "tick" to it, but, i've just learned to accept that it ticks. I think other people's does it as well, so it must not be too abnormal.
Like Mcqueen said, get some auto tranny fluid, remove 1 quart of oil, and put 1 quart of tranny fluid in it and see if that lubes it up at all and stops the ticking. Most likely, if you've never had your exhaust manifold replaced, you will eventually. Atleast welding things up isn't that expensive. It beats having to buy a new manifold itself.
I Removed My Door Dildos
Originally Posted by bullitt1680 View Post
Whyxitx's sixxer is so fast that the side scoops come off when he drives. How could anyone say that isn't fast.
2001 V6 - Needs faster engine
1995 Human - Needs BJ
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/207602-2004-mustang-convertible-v6-3-8l-clicking-cold-engine-start.html
Thread 2004 Mustang turbo v6 or TMA TURBO KIT - Page 2 | Forums at Modded Mustangs | BoardReader This thread Refback June 8th, 2011 02:14 AM
Threads Similar to: 2004 Mustang Convertible V6 3.8L - "Clicking" on cold engine start
To V10 or not to V10 "6.8L" 2004 Mustang GT Steele6599 99-04 230 May 13th, 2011 07:54 PM
00 Mustang won't start "no link" on odbII double0mustang V6 Mustangs 12 November 27th, 2010 10:26 PM
"Special Edition" Emblems On My 03 Convertible. Jealous V6 Mustangs 22 October 9th, 2007 07:06 AM
The return of "Stone Cold" Steve Austin homebrewed The Clubhouse 19 April 21st, 2007 12:27 PM
