#21 |
2004 v6 mustang
If i had to guess id say its the sensors behind the rotor, I just swapped out my rearend and had to disconnect my sensors from under the back seat, since i couldnt get the sensors to pop out. I think i broke one of them though. so now my abs light has come on.
You could try disconnecting / reconnecting the sensor from under the back seat ( there are two connectors on each side of the rear seat. ) or try cleaning the sensor that is behind the rotor ( little metal peice that sits just off of a gear looking device ) |
#22 |
Needs 2 cylinder bolt on
'03 Mustang V6
It's a six so what do you expect?
ok , looking into doing this tomorrow, found a write up on line on how to do it. Hopeful it's just dirty
#23 |
'03 Mustang V6
ok, so huge update.
Took the car in this morning to the shop that installed my exhaust. For 25 bucks he ran a test to see why the light was on. he scanned it and came back with the code : C1145 - which read Fight Front Speed Sensor input circuit malfunction. He then set it to see what it was reading. With the car at a stop, it read 2mph. When driving at 15mph, it read 26mph. anyways so I took the car home, jacked it up, took the wheel of and had a look. We clead what we could around the sensor, un plugged and re plugged the sensor, and then for the hell of it re greased the ball joints. So then I went to get the car washed. In the 20 minute drive, the light has yet to come on. But I can't confirm that we fixed it. Edit: light came on I'm going to have to send it into a shop cause I have no idea whats wrong.
![]() "you're alive for a reason, DON'T GIVE UP" Last edited by Mach Stang; March 12th, 2011 at 07:10 PM. |
Threads Similar to: ABS light
| Airbag Light, Brake Light, and Random (Pulley?) Whine | CarmenVI | V6 Mustangs | 11 | March 5th, 2011 03:15 AM |
| Head Light and Tail Light Opinion Needed | Laser | Visual | 8 | January 2nd, 2008 02:16 AM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 12:39 PM |
