installed my new stuff
Old March 13th, 2011, 01:01 PM   #1
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
installed my rims, tires, mach 1 chin spoiler and cut springs last night. very pleased with the results. i didnt end up cutting the rear springs because we ran into a little problem trying to take the bolt holding the rear axel to the rear control arm off. the bushing inside it was spinning and wouldnt let the nut loosen. anyways im glad we didnt cut the rears because i think it looks good as is. any lower i think would look goofy. also im glad we ended up cutting the fronts because one of the springs was broken on the bottom so we ended up having to cut more off anyway so we essentially eliminated a broken spring by cutting it more lol. i dont have a good picture yet because it was too dark in the garage when we finished it and it was dirty anyways. ill get pics up asap let me know what you think.
again thanks 6er for the info.
Old March 13th, 2011, 01:01 PM   #2
ag11hockey's Avatar
1999 Mustang V6
Old March 13th, 2011, 02:44 PM   #3
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
cant wait to see these pics man !!! hurry the hell up
yeah, when i put rims on mine, the rear end seemed fix its hiegth problem ... If I were to lower, i would just do the front.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old March 13th, 2011, 03:51 PM   #4
glad i could help...now don't forget the alignment lol
Old March 13th, 2011, 03:53 PM   #5
2004,1994,1967
14.37 @ 96
227whp N/A V6
Old March 13th, 2011, 03:54 PM   #6
2004,1994,1967
14.37 @ 96
and go somewhere you can trust ... place i went ended up charging 200+ dollars for some stuff they had to put in.
When i went to get my dad's car done, almost 600$
Took it to the ford repair shop ... 60$ ....
227whp N/A V6
Old March 13th, 2011, 06:45 PM   #7
tommy93's Avatar
2001 Mustang
tommy93 has a spectacular aura abouttommy93 has a spectacular aura about
what do you think is the maximum amount of springs to cut on some stockers so that you can still get your car properly aligned without CC Plates?
Old March 13th, 2011, 07:17 PM   #8
1.25 is safe...it can give you a slight negative camber, but alignment shops can use camber bolts to fix it...anthing cut after that will most likely need C&C plates
Old March 13th, 2011, 07:32 PM   #9
03 Mach 1
02Sandstorm is on a distinguished road
question: was your chin spoiler a little warped and bent.. did it end up being ok once you put in on?
Old March 13th, 2011, 09:35 PM   #10
ag11hockey's Avatar
1999 Mustang V6
Sorry its been shitty out all day and haven't gotten any good pics. Will do asap tomorrow. Yea ik I have to get an aallignment which will be easy because I work at a tire place. And the chin spoiler was a little bent but I left it inside and let it warm up a bit so it was more flexable when it came time to install
Old March 14th, 2011, 01:02 AM   #11
tommy93's Avatar
2001 Mustang
ok thanks... and is that 1.25 coils cut with the isos removed?
and how many inches do you think that 1.25 coils equals?
Old March 14th, 2011, 01:07 AM   #12
honestly first time after cutting run ISOs to see how low it gets...if you want it lower after a few weeks take them out...the ride will get a tad bit bumpy with them out, but you get used to it. and i'd say on both my GT and v6 i got a 1.5" drop
Old March 14th, 2011, 01:14 AM   #13
ag11hockey's Avatar
1999 Mustang V6
yea with the isos it doesnt seem like much of a ride quality difference between cut and stock but still has a good enough and noticable drop which is what i was shooting for. can definately say that for a cheap way to lower, cut your springs. this is only temporary until summer when i can afford to buy actual lowering springs and some CC plates lol.
Old March 14th, 2011, 01:23 AM   #14
1999 V6 Mustang
SALEEN961 will become famous soon enough
I get some new springs asap, if one of your springs was broken before, now that you've cut them your putting more stress on each coil and making each coil flex more since there's less of them, I'd think it's only a matter of time before it breaks again. I'm guessing the broken spring was rust related since your from NY.
Old March 14th, 2011, 12:45 PM   #15
ag11hockey's Avatar
1999 Mustang V6
it broke at the bottom inside the isolator. and i had to cut more off after the break anyways.
Old March 14th, 2011, 12:48 PM   #16
ag11hockey's Avatar
1999 Mustang V6
pics are up
Old March 14th, 2011, 12:52 PM   #17
ag11hockey's Avatar
1999 Mustang V6
oh and sorry the car is really dirty. havent had a good enough break in weather to wash it
Old March 14th, 2011, 09:40 PM   #18
2004,1994,1967
14.37 @ 96
sweet man, what size tires are those ??
227whp N/A V6
Old March 14th, 2011, 09:44 PM   #19
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
i never unbolted my rear control arm when i cutt my spings...
but it looks great
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old March 14th, 2011, 10:01 PM   #20
the backs a 275/40/17 according to the sidewall
Threads Similar to: installed my new stuff
Installed some new stuff today! NoColoradoGT 99-04 8 March 6th, 2011 05:22 PM
Dealer installed vs Factory installed AC? tigrshark 5.0 Mustangs 9 October 31st, 2010 10:20 PM
new appearance stuff installed!! iceguyb14 2005 - 2010 31 June 16th, 2010 11:20 PM
Couple of new stuff installed. Pics of car! mrsinister2424 Pictures 11 January 17th, 2010 07:32 PM
Gettin some stuff installed tonight, results in a day or 2 93hatch 5.0 Mustangs 5 July 3rd, 2008 08:54 PM
