Please Help...tough decision
I've got a 1999 V6 3.8 l Mustang. One morning I started it up and it started running real rough. Check engine code was misfire in 6. I replaced the spark plugs and wires. #6 plug was really bad. I was almost sure I had a faulty lifter (from friend's advice). I did a cylinder compression check and 1-4 were normal, 5 was a little low and 6 would not even turn over. The oil on the dipstick looks a little watery.
A Ford Certified mechanic took a look at it yesterday and said he is 95% sure that I have a blown head gasket. He said that if I take it in to the shop, they will replace the head gasket and send the head out to be tested for cracks. He said it should run about $900 to $1,000 for the job depending on the shop I take it to. He said if it were him, he'd buy a used engine from a salvage yard and swap engines. I've done some shopping and I've found an engine for $525 (64k miles, 6 month warranty). To get it swapped I'm looking at another $300 give or take. I have no garage and novice knowledge about engines, but I am handy enough I think I could replace the gasket and any other wearing part (lifters, pushrods, valves, etc.). What should I do guys? Thanks |
48.47@ 12.58
replacing a head gasket is no joke.
but if you think you for sure are able to do it go for it. you need all the TQ specs and there is a certain way to unbolt and bolt the head back on. good luck
good luck
we're like then an 's like and Im like :lala then we're like then Im like :award then he's like then everyones like you got then he's like I got Im like
i would get the Junk yard engine and keep the old one strip er down and build your self a nice engine slowly then when its done throw er in.
Thanks for advice.
I am really leaning towards the used engine. Rebuilding the used engine slowly is out of the question..... I am stuck in a minivan for 2 hours a day. I have found a friend with a garage that will swap the engines for me and he said he would help with slightly rebuilding the used engine (new gaskets, etc.) When I'm finished I plan on modding it a bit (new exhaust, cold-air intake, pulleys) |
#6 | |
Gotcha....I need to find a space to tear it down, but that is a great idea. Most of the salvage yards wanted to trade, but I had planned on keeping my old engine for parts.
What is the advantage of replacing the stock headers? I assume better exhaust air flow? |
#8 | |
Re: Please Help...tough decision
If you did do it yourself, a head gasket, new head bolts, fresh oil would be pretty much all you need and would probably run you less than $75. Add a chilton manual for instructions, be neat and very organized when taking it apart and it would save you alot of money. However, your cylander head could be cracked, but i looked it up and its $200 used on carparts.com. Still under $500. So it would be a headache if its your first time working on a motor, this deep, but it would save alot of money.
hell just get an old 4.2 and build it and cram it in there! vrooom vroom
¡ʇsnq ɹo uʍop ǝpısdn
get new heads of a junked motor... have them port and polished then switch them in their... that will cost you about $500 for used heads and getting them ported... then $100 in install... and your friend can help you with the detailled part... such as torquing all that shit in and making the crucial stuff fit right
Threads Similar to: Please Help...tough decision
| VERY VERY TOUGH!!!!! | mustang1072 | V6 Mustangs | 132 | October 21st, 2007 03:15 PM |
| Man that was tough | Cricket | The Clubhouse | 45 | September 23rd, 2007 07:14 PM |
| First gear is sometimes tough to get into | jam77 | 5.0 Mustangs | 4 | June 14th, 2007 08:22 AM |
| Talk about tough | turp | The Clubhouse | 5 | August 27th, 2005 10:23 AM |
