Lowering springs
Ive been looking into getting lowering springs but I need some advice. Right now I bought the car with cut springs but I love how it looks the height. Is there a way I could measure the drop to get springs comparable or what would you guys suggest? What kit or how much of a drop? Thanks
How much of a gap do you have between your tires and the fender right now? A stock suspension will have about 5-6 inches of a gap. You can judge how much the cut springs are lowering your car by that. Then go get springs that are comparable.
IMO, i would leave the cut springs on there. Is there a reason that you want lowering springs instead of cut springs?
2004 3.9L Vert (sold) |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Take a picture of your car... Leave the cut springs imo
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
I want to get lowering bc with the cut its rough. bottoms out a lot.
Better than ONLYaUNCfan's
2012@lightspeed
How much are they cut, are your shocks and struts good?
Formerly, AhobosCheese and Cheddars.
Lets just say if i jack the car up by the body and not under the rear end. The rear springs fall out so i welded a little piece of pipe in there to hold them in. And idk how to check the shocks to see if there good i haven't changed them so idk how many miles they have on them.
#9 | |
2012@lightspeed
1-2 ok. 3+ bad. How many miles are on the car?
1 Wheel Peel
2000 Mustang 393w
3 is the general rule that it's okay.
Don't let hobo fool you
2002 Nitrous Injected V6
12's?
Can someone give me a ballpark drop for 1 1/4 coil cut off stocks and 1 1/2. Both with isos in
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
Side:
![]() As you can see the tires tuck up inside of the finders so i can't get a measurement unless its negative. Also i have 17" rims so there not factory. Front: ![]() Rear: ![]() Don't mind the dent. Lol stupid snow. |
holy fucking shit...either you have 3 1/2 coils cut or you have the worst f'ing shocks
![]() i'd buy them first..then look into springs |
Dancing Naked In The Rain
OP are you running on the factory shocks and struts? You've got enough miles on your car that they should be worn out. I changed mine at 100k and they were so worn I could easily compress them by hand and they barely pushed back out. I completely agree with 6er, look into a nice set of shocks and struts before you go looking for new springs.
1 Wheel Peel
2000 Mustang 393w
It's dropped on It's ass. Nice lug nuts lol
2012@lightspeed
Threads Similar to: Lowering springs
| Drag springs or lowering springs??? | AggieStang | General Tech | 10 | February 18th, 2012 12:45 PM |
| stock springs vs lowering springs in drag | TotoGT06 | 2005 - 2010 | 4 | April 14th, 2010 10:25 PM |
| Lowering Springs | John's_stang | 99-04 | 36 | April 5th, 2009 09:13 PM |
| 2'' Lowering Springs? | 01 GT | 99-04 | 11 | January 5th, 2008 01:20 PM |
