So with my V6 how do i get my tire to chirp like other V6's?
Closed Thread
Old March 22nd, 2011, 12:45 AM   #1
MustangGeek is infamous around these parts
So with my V6 how do I get a firm shift to chirp my rear tires when shifting/
So I have a V6 3.8 Auto Trans dual exhaust flowmasters.
I like the sound of having my tires chirp when shifting gears.
i know it has to be a firm shift but how do I get it?
I heard some people did it buy tuner, some by shift kit etc..
What is the best way to get the chirping sound when shifting gears?
can someone help me out?
I'm still kind of confused as to which tuner I need if I go that route and where to by it from..
Thanks
Old March 22nd, 2011, 12:47 AM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Auto or manual?
My Hubpages
Hey.. r u really a tranny??
Old March 22nd, 2011, 12:51 AM   #3
Shelby's Minion
RZNCAIN's Avatar
2007 Mustang Shelby GT
(Mach1) Sept. '10 ROTM
RZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud of
engine swap?
Sponsored by Specialty Coatings
Car Salesman Club- Founder
2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked
1988 LX 5.0- Umm...Driver?
Old March 22nd, 2011, 12:55 AM   #4
mcqueen's Avatar
I suppose I could explain either way.
Auto:
Method 1
-Hold the brakes
-Rev the engine up a bit (you should be able to chirp them at 1500-2000RPM easily)
-Take your foot off the brakes
Method 2 (hard on your transmission)
-Put the car in neutral
-Rev up like method 1
-Drop into Drive (called a neutral drop or something like that)
Manual
-Put the clutch in, put the transmission in 1st gear
-Rev the engine up
-Dump the clutch
If you keep pressing the gas harder after you let out the brakes/clutch then the wheels will spin (burnout) until they get traction. Using method 1 you can get the tires to spin while the brakes hold your front tires in place (you have to find a good balance where you can break the rear tires free but still have enough brake power to stay in one spot). With a manual you can dump the clutch and quickly use the brakes to keep yourself from moving (again finding a good balance to overcome the braking power in the rear while maintaining enough to stay still).
Be aware, police will pull you over for doing burnouts or chirping your tires.
If you're looking to mod, a tuner, gears (4.10 or 3.73), and a tlok are great choices to start with. The tuner will correct your tach and speedo for the steeper gears (plu shift points if you're auto), steep gear ratio will help you accelerate quicker and I feel like it' easier to spin my tires with 4.10 gears, and a tlok will allow you to spin both rear wheels (right now only 1 of your will spin due to your open differential).
My Hubpages
Old March 22nd, 2011, 12:55 AM   #5
#TFM
NoColoradoGT's Avatar
NoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of light
Ummm punch the gas pedal?
dump the clutch?
I used to get my 2007 Mazda 6i while it was N/A to chirp the tires like crazy...and that was a 3,800 lb. family sedan with a 158 bhp 2.3L.
2002 Mineral Gray Mustang GT
Slow. Sexy.
MM's Car Salesman Club
MM's Resident Actor
ΠΚΦ
For life.
Old March 22nd, 2011, 12:57 AM   #6
sc55509's Avatar
2011 V6
13ish@105 mph
sc55509 is on a distinguished road
If it is a manual just get really good at popping it into gear...more hp would not hurt either.
C&L cold air intake
SCT X3 tuner
Ford Racing 3.73's
Flowmasters
BBK Lontubes
BBK O/R x pipe
UMI LCA's
Old March 22nd, 2011, 12:58 AM   #7
Auto or manual?
Auto
Old March 22nd, 2011, 12:59 AM   #8
mcqueen's Avatar
I'm not sure what year he has, but if it's a 94-98 I'm not sure it would be able to chirp the tires with a simple gas pedal mash. Those things were weak I'm sure a 99-04 could do it though
My Hubpages
Old March 22nd, 2011, 01:03 AM   #9
Sorry I meant the chirp you get from a firm shift
Old March 22nd, 2011, 01:07 AM   #10
mcqueen's Avatar
That you will need a tuner for (I recommend the SCT X3 or SF3). And that's not the sort of tune you want to run every day. Basically you would need a tune to stiffen up your shifts and shift much higher than your stock tune is set for. And gears + tlok are some things you should consider to help out. But honestly, gear + tlok + tuner just to chirp the tires is probably going to cost more than you think. Expect around $800 for the gears, tlok, fluids, install/rebuild kit, and labor for the install then another nearly $400 for the tuner (supposing you get it from AmericanMuscle with the free tunes option).
Another thing you could try is manually shifting your car. I believe you get at least a 1st and 2nd gear option. You'd just need to run the RPMs pretty high and essentially power shift (don't take your foot off the gas between shifts). I'd be willing to bet the cars you hear chirping their tires between gears are manuals. It's much easier with a manual (trust me).
My Hubpages
Old March 22nd, 2011, 01:14 AM   #11
Wing on, wing off...
MRKsD3's Avatar
JULY 2011 ROTM
MRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of light
With stock V6 wheels plus a tuner.... at least mine did the "chirp" when I put my stockies... They're significantly lighter than my 18" Saleens...
SIG BY WABASHACOBRA99
Old March 22nd, 2011, 01:30 AM   #12
Thanks
gears I found for $100 and my mechanic is going to put it in for $200
Tuner probably wait until cold Air intake installed and spark plugs
Old March 22nd, 2011, 01:50 AM   #13
2000 Mustang V6
xsoulscarz53x is on a distinguished road
Originally Posted by MustangGeek View Post
Thanks
do t-lok while your at it, same area no extra cost in labor
Old March 22nd, 2011, 01:56 AM   #14
2000 v6 mustang
1slowv6 will become famous soon enough
oh come on now i can get my 100% stock motor, gears etc. to chirp no problem with 17's and 245's in back.
i have an auto the only thing i do is go through the gears myself from a stoplight i put it in 1st and right when it hits 5k put it into 2nd and it chirps into gear everytime
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old March 22nd, 2011, 02:01 AM   #15
MRKsD3's Avatar
JULY 2011 ROTM
Wouldn't that be too hard on the your tranny?
Old March 22nd, 2011, 02:06 AM   #16
Im not trying to tear up my transmission.
Old March 22nd, 2011, 03:28 AM   #17
1999 V6 Mustang
SALEEN961 will become famous soon enough
My stock 99 with 245's on '98 Stang 17's chirps 2nd everytime, and if I'm real quick or have my short shifter handle on the car instead of the factory one I'll chirp 3rd.
Old March 22nd, 2011, 03:30 AM   #18
2000 v6 mustang
when i let it do its thing it shift at 5500 at WOT
Old March 22nd, 2011, 03:31 AM   #19
sc55509's Avatar
2011 V6
13ish@105 mph
If your going to do gears do tlok, and unless their lending you a speedcal your gonna want a tuner pretty soon because your speedo will be off.
C&L cold air intake
SCT X3 tuner
Ford Racing 3.73's
Flowmasters
BBK Lontubes
BBK O/R x pipe
UMI LCA's
Old March 22nd, 2011, 05:12 AM   #20
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
He does have a point. I mean as long as your pretty heavy on the gas pedal constantly if your doing the "manual shifting" thing. You should be ok, but sitting there at 4k rpm just cruising will cause excess heat which in turn leads to part failure.
On a personal note I have heard my car "chirp" from shifting from 1st to 2nd then from 2nd to 3rd. This was of course at the track, I don't have a heavy foot on the streets... Thats illegal.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Closed Thread
Threads Similar to: So with my V6 how do i get my tire to chirp like other V6's?
Chirp 1-2 Shift Auto GP-SE 99-04 9 August 5th, 2010 03:07 PM
Chirp from tranny Nossit 99-04 9 May 24th, 2010 02:16 PM
Belt chirp problems genericcobra 4V / SVT 0 October 6th, 2008 08:07 PM
Belt chirp on shifting militant54 94-95 9 April 7th, 2008 12:45 PM
Serpentine belt system chirp whitemustang02 V6 Mustangs 6 October 1st, 2007 03:17 AM
