How to cut the rear springs?
Old March 22nd, 2011, 04:53 PM   #1
jakeabraham's Avatar
2003 Mustang V6
jakeabraham is on a distinguished road
I've already done the 2 front springs and i cut 1.25 coils off. The rears are being difficult, first of all, I don't think I've seen a how-to on cutting the rear springs, but it seemed simple. I tried to disconnect the control arm from the axle and drop the control arm down slowly with a jack, but i could not get that screw out, it was like stuck in there, and theres not really any way to beat it with a hammer, i have a feeling thats not the right screw to remove to get the control arm down or something, idk. so how do i remove the rear spring? also.. the spring on the back looks different and im gonna assume i gotta cut from the top, do i just cut one coil off the back like where the end of the coil is cut there on the coil below? it looks like on the rear the springs are alot closer towards the top and that cutting just 1 coil wouldnt really do a whole lot. correct me if im wrong, and sorry its kinda hard to explain some of this shit in words. haha.
Thanks,
Jake.
Old March 22nd, 2011, 07:05 PM   #2
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
tip.
Unbolt the shock where it attaches to the axle (both sides). Then use the jack and prop the opposite side up and it will shift the axle. Then simply remove and repeat.
1 coil off is correct.
Formerly, AhobosCheese and Cheddars.
Old March 22nd, 2011, 07:21 PM   #3
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
Just take off the shock and you should be able to get to the spring. was going to cut my springs today but the sawzall didnt have any blades that could cut the spring, they call just kinda scratched it up. Tomorrow im going to get ahold of a grinder =]
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old March 22nd, 2011, 09:00 PM   #4
Originally Posted by Ahoboscheese View Post
tip.
easy way is easy
Old March 22nd, 2011, 09:31 PM   #5
Absens haeres non erit
Alexander III's Avatar
'11 Performance Package
4.61@356.68
Alexander III will become famous soon enoughAlexander III will become famous soon enough
Do a search. There are a couple of write up's floating around.
I'm on my phone.
Current:
'12 VW CC Sport 6MT | '10 Jetta TDI | '08 350Z Vert | '95 S14 | '85 325e
BUY MY SCT X3 UNLOCKED USED TWICE
Old March 22nd, 2011, 09:33 PM   #6
I'm on my phone.
it's all good...hobo gave him the best way to do it.
Old March 23rd, 2011, 01:29 AM   #7
2003 Mustang V6
tip.
So jack up one side, than put another jack under the axel on same side, remove shock bolts on both sides of car, and let the jack under the axel down?
Old March 23rd, 2011, 01:37 AM   #8
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
i had the same problem with those bolts lol. i was going to do it the way everyone just said to but i was too lazy to unbolt my exhaust. stupid shitty y pipe
Old March 23rd, 2011, 01:39 AM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
you can also just put a jack under the rear, remove both lower shock bolts, let the jack down allowing the rear to just hand. From the side you are working on, push down on the axle and pull the spring out.
Old March 23rd, 2011, 12:06 PM   #10
BlueScreaM's Avatar
2012@lightspeed
No, you unbolt both shock bolts and only jack up one side and let the other shift down then remove the spring on the one that shifted down.
2 min drawing FTW!!!
Threads Similar to: How to cut the rear springs?
What rear springs to get? davidz 99-04 7 February 20th, 2011 05:54 PM
Rear Springs In wveil3v 2005 - 2010 12 March 29th, 2010 12:17 PM
