1996 3.8L V6 Mustang
Too embarrassed to take to track.
CAI Help
What is the sensor after the MAF sensor? And should it be facing the same way the MAF sensor is? Mine's not; facing towards the walls of the intake pipe. One more. Can I clean whatever this sensor is with the MAF sensor cleaner? Thanks
Not Banned
i believe that you are talking about the IAT
so im going to assume that you have a 99 or 00? does it look like this? ![]() this is how it should look from the inside
its a 96. but yea that's it. so mine's facing the wrong way i guess...
#4 | |
Not Banned
I ran mine just hanging loose in my engine bay for a day before i could get a bit for my dremel to make a hole for it in the windstar swap tubing and i didnt see a change in anything. and making it face the right way is no big deal, it would literately take like 2 seconds. |
'00 V6 Procharged Mustang
IAT = Intake Air Temperature
![]() But yeah, you should be able to just rotate it so that it looks like the picture posted from the inside. It's not likely to cause problems either way though.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
#6 | |
Not Banned
i am way to tired, i wonder where i got that from.
thanks guys. whoever owned the car before me siliconed this piece in place so i can't just rotate it. but yeah it's totally facing the wrong way to where the air can't hit the sensor properly. i'll fix it just for piece of mind.
1999 Mustang V6
![]() iTrader: 3 reviews
Yeah it makes pretty much 0 difference, especially on a stock n/a car. But do it if it makes you feel better.
Twin Turbo |
Formally Ur PaNic
2002 Mustang GT 4.6L
I just installed my Cold Air.. is a gentle hiss/sucking normal? Just a quick question I had
![]() But yes, IAT 99-00 models and early have on, I didn't on mine which confused me at first.
![]() 2002 Ford Mustang 4.6 GT Coupe 4-spd Awesomatic - B&M Hammer - Procharger P1sc - 3 Core Intercooler - SCT Xcal3 - SSS Terminators DGR / Dave Guy Tuned 354 rwhp / 365 rwtq |
1999 Mustang V6
The sound is normal, as long as it's not a vac leak =P which would give you some sort of problem like a shitty idle.
Twin Turbo |
Formally Ur PaNic
okay well after adding the Cold Air intake my idle went down to 600-700 from 800-1000 rpms at start up
so I'm good, sweet. Some of the rubber things I was scared of having the pipes not all the way in
