#21 |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
i figured that, but even with boost i think it would show a difference. id guess that the cut/weld makes more hp and the windstar more torque.
2004 Bolt on & Cammed 3.9L V6 |
#22 |
1999 Mustang V6
![]() iTrader: 3 reviews
Well, the ability to pick up power with the stocker is in that you can remove the posts and then also open up the entire length of the runners to the gasket dimensions if you want. The windstars runners are plastic and cannot be opened up. The stock manifold's runners are shorter, though, resulting in less tq. To get the best of both worlds, you can do an F-150 upper, which is an auminum version of the windstar, but even longer runners IIRC which is why it doesn't clear the stock hood.
Twin Turbo |
#23 |
2000 Mustang
slow@slow
How hard is a cut and weld job? Is it even worth the gains? How long does it take? Ill have a good mechanic helping me and he said he could port and polish easy so i imagine a cut and weld could be much harder
#24 |
Formerly 01silversixer
2001 V6
15.47@89.57
Hey paul how you wanna work out the windstar?
I sent you a pm on 3.7 a couple days ago |
#25 |
1999 Mustang V6
Just PM'd you over there silversixer lol
And as far as the gains for a complete cut and weld...I'm not really sure. I'm fairly sure I'm just going to leave the rest of the manifold as it is since I can just run like 2 psi more and way more than make up for it. I do believe the biggest gainst you will get are from removing the posts, and a little less from the gasket matching as far up the runner as you can. You really don't need to 'polish' anything, just like the finish if you can really see it on mine, not exactly smooth to the touch. It seems like a lot of extra work to do the cut/weld especially if you're not even running FI, the gains will really be minimal. You're primarily restricted by stock cam, then probably heads next.
Twin Turbo |
Threads Similar to: Stock Upper Porting/Post Removal
| Removal/install of upper intake manifold | Stang6899 | V6 Mustangs | 9 | February 14th, 2008 12:54 PM |
| Anyone Have A How To On Porting An Upper Intake? | tjames | V6 Mustangs | 34 | December 7th, 2007 01:16 AM |
| upper&lower intake porting w/Throttle Bdy port | SPF0percent | V6 Mustangs | 9 | May 6th, 2007 11:04 PM |
| porting upper intake and throttle body | 02ponypackage | V6 Mustangs | 16 | April 29th, 2007 03:59 PM |
