Stock Upper Porting/Post Removal
Old March 23rd, 2011, 08:10 PM   #1
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
Well I had some free time the last couple days and have been doing some work on the car. I'm selling the windstar to free up some money and because that's the easiest way to run the piping to the TB. Here are some pics for anyone who might care. All I have to do now is cut the piece of aluminum plate for the top and put a few screws in it.
Just the porting. I didn't make them terrible smooth because apparently you're not supposed to. And a also didn't have any sanding cartridges at the moment.
Using the carbide cutter in a drill press to do the actual post removal, still leaving a flat finish for the manifold bolts inside.
This is what it looked like after I ground the posts down.
Then I removed the upper hollow sections of the posts with a hole saw in the drill press.
Here's what the view from the throttle body opening looked like when done. It looks as if it freed up a little less than 1/3 of the cross sectional area, which I didn't remember to take a pic of before for reference.
And here's where I'm going to cut the plate, seal it, and screw it down.
Here it is, done but without screws lol
Twin Turbo
Old March 23rd, 2011, 08:31 PM   #2
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
I'm confused by what the posts are...someone explain?
Build Thread
Old March 23rd, 2011, 08:36 PM   #3
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
what about the rest? are you doin a full cut & weld job?
2004 Bolt on & Cammed 3.9L V6
Old March 23rd, 2011, 08:38 PM   #4
9986paulk's Avatar
1999 Mustang V6
If you look at your stock upper, you have 2 posts that go down directly through where the air flows right after the TB. It was designed that way to be easy to manufacture and to bolt it down easily. And plus it was for a V6...lol
Twin Turbo
Old March 23rd, 2011, 08:40 PM   #5
9986paulk's Avatar
1999 Mustang V6
I'm thinking about doing the cut/weld since it's only like 2 more cut pieces and I have a welder. I may not though since I'm just running it for this year pretty much, then doing the swap. I'm just not sure it would be worth it. I could just up the boost a tuny bit and be exactly the same.
Twin Turbo
Old March 23rd, 2011, 08:42 PM   #6
SlowSix's Avatar
2001 V6
15.47@89.57
Gotcha. I never really looked at the stock upper all that much.
Build Thread
Old March 23rd, 2011, 08:43 PM   #7
walt1120's Avatar
14.45 @95.8
i havent been on here in a while, what swap are you doing next year?
Old March 23rd, 2011, 08:48 PM   #8
9986paulk's Avatar
1999 Mustang V6
Well right now I'm doing TT on the 6 which should be done in the next week.
Next year I'm swapping in a built 4.6 and building another TT kit for that using the same turbos. And I'd like to use a manula tranny, but as far as cost vs. strength idk for sure at this point. Just something different.
Twin Turbo
Old March 23rd, 2011, 08:56 PM   #9
walt1120's Avatar
14.45 @95.8
sounds good man, 4v im assuming? if you do go manual go at least t-56. a lightly built 4r70w is pretty bulletproof though
Old March 23rd, 2011, 09:08 PM   #10
9986paulk's Avatar
1999 Mustang V6
Yeah that's the thing there's like a $2k difference between a t-56 and the auto. But no, it's a 2v. I thought about it, but since I'm forging it and running FI it seemed like it would just cost more to get where I want with the extra cost of a 4v. Even though they do sound amazing. But I think with cams this will sound pretty good too, even with the turbos.
Twin Turbo
Old March 23rd, 2011, 09:24 PM   #11
walt1120's Avatar
14.45 @95.8
yeah you can just turn up the boost a little to make up for it not being a 4v lol.
Old March 24th, 2011, 12:49 AM   #12
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
how dare you hack up my upper intake
But seriously, why not just go with the windstar if you have a welder to modify the cold side?
H/C/I V6
BMC Member: 12521
Old March 24th, 2011, 08:10 AM   #13
SlowSix's Avatar
2001 V6
15.47@89.57
I'm assuming its easier to route the piping for the coldside with the stock upper rather than the windstar
Build Thread
Old March 24th, 2011, 09:31 AM   #14
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Well it is but I would think that it would be about as much work as a cut n weld job.
H/C/I V6
BMC Member: 12521
Old March 24th, 2011, 11:13 AM   #15
9986paulk's Avatar
1999 Mustang V6
Well this took me about 4 hours to do the entire thing. But the way I looked at it was I'll be able to get some money back out of this when I sell the engine at the end of the year and put the 4.6 in. An plus, to do the windstar with it, I would've had to move the power steering lines at minimum and maybe the coolant tank because now I have turbo piping to run into where I routed the piping before.
Twin Turbo
Old March 24th, 2011, 11:24 AM   #16
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
So, you took out the post to increase air flow? Never heard of that or even looked that close at the upper intake before...What gains are you expecting from that?
For Sale:
99-04 smoked tail light covers
Old March 24th, 2011, 11:45 AM   #17
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Some people say that a full cut n weld upper intake is one of the best options. There is a guy on v6p who cut his to pieces and pretty much doubled the size of the inside.
When I get home from school I will find the link
H/C/I V6
BMC Member: 12521
Old March 24th, 2011, 11:57 AM   #18
walt1120's Avatar
14.45 @95.8
id like to see a dyno test between a cut/weld stock vs windstar.
Old March 24th, 2011, 12:01 PM   #19
w00v6 is on a distinguished road
I'd like to see that dyno test, too.
Old March 24th, 2011, 12:35 PM   #20
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
You'll never see that because anybody who is doing a cut and weld is prob doing it on a boosted motor.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Threads Similar to: Stock Upper Porting/Post Removal
Removal/install of upper intake manifold Stang6899 V6 Mustangs 9 February 14th, 2008 12:54 PM
Anyone Have A How To On Porting An Upper Intake? tjames V6 Mustangs 34 December 7th, 2007 01:16 AM
upper&lower intake porting w/Throttle Bdy port SPF0percent V6 Mustangs 9 May 6th, 2007 11:04 PM
porting upper intake and throttle body 02ponypackage V6 Mustangs 16 April 29th, 2007 03:59 PM
