2000 3.8 v6 5 spd manual tranny swap out??
Old March 26th, 2011, 02:45 AM   #1
abbe5710 is on a distinguished road
Exclamation
Hey there, I'm pretty new at this but I really need some advice about my 2000 'stang..
Ive had the car for about 5 years now, apparently am in need of a new tranny but am unsure as to whether or not one from a 98 manual would be compatible or not?
Everything is stock in my vehicle except for exhaust, its a v6 manual 5 speed and when i check the door panel for the description under "TR" it reads:
'5 mmzz'
which ive been told is significant as to which tranny may or may not match up to the vehicle? As far as whether or not the 98 tranny will fit, i have had a hard time getting a straightforward answer! Any advice would be greatly appreciated! Thx for your time!!
Please let me know if I need to post add'l info!!
Old March 26th, 2011, 03:04 AM   #2
Dancing Naked In The Rain
mcqueen's Avatar
I believe the tranny itself should work fine (T5 was the only manual transmission offered to 94-04 V6s). I'm pretty sure you'll need a clutch for the 99-00 models (unless your current one is relatively new, this is a great chance to change it) and you may need to reuse the bellhousing from your current transmission (not sure if they changed between the pre-99 and 99-04 models).
'5 mmzz'
The only part of this code that matters is the first number. The 5 indicates that the transmission is a T5 5-speed manual transmission. That's an easy call on most V6 Mustangs though because Ford has been putting the T5 in V6 Mustangs since 1979 I believe.
My Hubpages
Hey.. r u really a tranny??
Old March 26th, 2011, 03:15 AM   #3
Ah! Thank you SO much for your help! My dad and I were a bit out of sorts with it all, I actually ran the tranny fluid out and burned my clutch and tranny up before we caught the leak.. So, replaced the clutch about 3 months ago! Were able to make the transmission work till we could find a good deal on a new one ( which we found for $150.00! ) Quite the steal! The car has almost 200k miles, and is goin' strong! She's a beaut!
Thanks again for your help, Mcqueen!
Old March 26th, 2011, 03:21 AM   #4
mcqueen's Avatar
Not a problem man. It should be a very straight forward swap since it will basically be the same transmission And welcome to MM
My Hubpages
Old March 26th, 2011, 09:46 AM   #5
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
Off topic, but I didn't feel like making a thread about it.
What kind of built T5s are there?
Build Thread
Old March 26th, 2011, 02:58 PM   #6
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
i think you may need a different speed sensor too. i think the older t5s out of the 94-98 used a mechanical speed sensor.
Old March 26th, 2011, 03:00 PM   #7
ag11hockey's Avatar
1999 Mustang V6
and to answer your question silver, theres TKO T5's, the tremec 3650, and a few other ones too. the 3650 isnt really technically a T5 but they are very identical
Old March 26th, 2011, 06:43 PM   #8
SlowSix's Avatar
2001 V6
15.47@89.57
What is the difference between a T5 and a WC T5?
Build Thread
Old March 26th, 2011, 10:54 PM   #9
AndyG47's Avatar
2002 Mustang V6
Slow
AndyG47 will become famous soon enoughAndyG47 will become famous soon enough
WC t5 is newer and holds a bit more power - not much though
_
2003 F150 - 5.4L V8 4x4 - 109K hard miles & still going FORD Tough----2002 Mustang 3.8L V6 - Currently undergoing "I'm not 17 anymore" demoding
Originally Posted by OneShotOneKill View Post
this thread has more fail in the first 5 posts than all of the "what exhaust?" threads in the v6 section.
Threads Similar to: 2000 3.8 v6 5 spd manual tranny swap out??
01 auto tranny swap to manual SON1C V6 Mustangs 13 September 2nd, 2010 01:54 PM
manual tranny swap jasons_98gt 96-98 4 February 10th, 2010 12:37 AM
Auto to Manual Tranny swap? jdevarie 94-95 3 February 2nd, 2010 01:47 PM
V6 Tranny Swap (Auto to Manual) HELP!! Blue Demon V6 Mustangs 17 July 6th, 2008 01:36 PM
Automatic to manual tranny swap loon 96-98 7 January 31st, 2008 12:37 PM
