setting tdc - Page 2
Old March 29th, 2011, 02:08 PM   #21
02edge's Avatar
2000 m112'd 3.8
02edge will become famous soon enough
so are there timing marks or there are none
Old March 29th, 2011, 03:01 PM   #22
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
you might actually need to rotate the crank 180 degrees more.
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old March 29th, 2011, 03:02 PM   #23
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
you might can get the oil pump turned to the proper position, idk. But it maybe a shot in the dark-Trial and error phase. The synch gears are slanted: \\ Not up and down: ||
so when you drop it in place, the center piece you see will have to slightly spin to set the gear all the way down. Now remember, that piece should be set to the center of the gap in TDC, if I remember correctly that is. So you will have to off set the center piece so that when it turn while inserting, it will line up when finished seating.
Now if your doing all that correctly and its still not lining up and going in, chances are, its hitting the oil pump and not inserting itself there. That maybe why its not going in.
It shouldnt take to much effort to get it to slide in, Replacing a new one, might have some different wear pattern and may cause some friction. But I doubt its that much.
When I put my stock one back in, things lined up nicely, just a small amount of push and wiggling to get it to fall into place.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old March 29th, 2011, 03:57 PM   #24
02edge's Avatar
2000 m112'd 3.8
well napa gave me the three wire sensor so I used my old two wire sensor on the new assembly put it all back together but now it wont turn over any ideas what it could be im guessing its not getting spark at all because if it was it would run atleast crappy so is the sensor wrong?
Old March 29th, 2011, 05:53 PM   #25
2004,1994,1967
14.37 @ 96
double check all your wiring.
227whp N/A V6
Old March 29th, 2011, 08:05 PM   #26
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
It should just go back down in with a little shaking and turning. Then for finding TDC get a wire brush and brush your crank balancer to find it, that's what I did. Then just rotate it til the piston blows your finger out of the spark plug hole. Then line up the mark with the pointer. As far as it not turning over, idk...I think the cam sensor controls fuel. It should still turn over as far as I know.
Twin Turbo
Threads Similar to: setting tdc
Need Help setting my amp pennstate Audio/Video 16 February 2nd, 2010 03:37 PM
Setting A BOV shadowgames81 SVO 26 January 7th, 2009 06:13 PM
Setting Timing? 05gtdroptop 2005 - 2010 22 December 18th, 2008 08:09 AM
setting the timing dr.gonzo! 5.0 Mustangs 10 March 31st, 2008 05:34 PM
setting TPS wildfaststang 5.0 Mustangs 6 August 27th, 2007 10:47 PM
