LinkBack (1) | Thread Tools |
#1
3.8 Torque Specs
3.8L Torque Specifications*
V6 Engine (ft-lbs unless otherwise indicated) Camshaft sprocket bolt........................................30 to 36 Camshaft thrust plate bolts .................................72 to 120 in-lbs Timing chain cover-to-pock bolts ........................15 to 22 Water pump-to-timing chain cover bolts.............15 to 22 Oil pan mounting bolts ........................................84 to 108 in-lbs Oil pump and filter body to front cover 8mm bolt.............................................. ..........17 to 23 6mm bolt.............................................. ..........72 to 96 in-lbs Cylinder head bolts 1994 and 1995 Step 1................................................. .........15 Step 2................................................. .........29 Step 3................................................. .........37 Step 4................................................. .........Loosen 2 to 3 turns (DO NOT loosen all the bolts at the same time, from this point on work on one bolt at a time) Step 5 Long bolts............................................. ...11 to 19 Short bolts ...............................................7 to 15 Step 6................................................. .........Tighten an additional 90-degrees 1996 and later Step 1................................................. .........15 Step 2................................................. .........29 Step 3................................................. .........36 Step 4................................................. .........Loosen 2 to 3 turns (DO NOT loosen all the bolts at the same time, from this point on work on one bolt at a time) Step 5 Long bolts............................................. ...29 to 37 Short bolts ...............................................11 to 18 Step 6................................................. .........Tighten an additional 180-degrees Rocker arm fulcrum bolts 1994 and 1995 Step 1................................................. .........44 in-lbs Step 2................................................. .........19 to 25 1996 and later Step 1................................................. .........44 in-lbs Step 2................................................. .........22 to 29 Intake manifold-to-cylinder head bolts 1994 and 1995 Step 1................................................. .........96 in-lbs Step 2................................................. .........15 1996 and later Step 1................................................. .........72 in-lbs Step 2................................................. .........108 in-lbs Exhaust manifold bolts ........................................23 to 26 Crankshaft pulley-to-vibration damper bolts .................................................. ............20 to 28 Valve cover bolts .................................................7 2 to 108 in-lbs Vibration damper bolt..........................................103 to 132 Flywheel/driveplate mounting bolts .....................54 to 64 Wheel lug nuts.............................................. .......85 to 105 Spart plugs .................................................. ........7 to 14 Firing order............................................. .............1-4-2-5-3-6 *After assembly, retorque with the engine hot. |
great post! now i dont have to look all this stuff up
thanks
![]() my vehicles: 1996 Mustang v6 232 ci 1969 F100 stepside inline six 300 ci www.mooresvilledragway.com www.shadysidedragway.com |
couldn't leave all my little v6 brothers out.....
1999 Ford Mustang V6
14.79 @ 92.15
thanks man, your little brothers thank you
good
now make it a sticky
#6 | |
My Stallion is Bigger!
.. sorry but I dont really understand whats being listed here.. is it a list of what to do to gain more rear torque??
no, it's a list of how tight the bolts for a particular item need to be when you are re-assembling an engine
can you do the pressure plate and flyaheel bolts also
I Have A 2002 Mustang V6 And My List Of Modds Are: Performance Chip,intake,mac Headers ,x Pypes (just 2 Cats Deleted) ,duals And Msd Wires.
I Havent Tested On A Dyno So Can Anyone Tell Me An Estimate Of Numbers That I'm Putting To My Car? |
Fashion Guru
this was not the right place to post this. this is talking about how much torque you need to put on bolts on the car, not how much torque youre putting out
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/2112-3-8-torque-specs.html
| noise in the bellhousing - V6Power Messageboard | This thread | Refback | March 10th, 2008 01:27 PM | |
Threads Similar to: 3.8 Torque Specs
| 4.6 Torque Specs | Twist 2 Go | Modular Mustangs | 29 | June 21st, 2010 01:32 AM |
| torque specs | mmvi | V6 Mustangs | 10 | September 16th, 2007 06:09 PM |
| Crankshaft torque specs anyone?? | stanglifemike | 2005 - 2010 | 18 | August 22nd, 2007 01:11 PM |
| Torque specs | G.T. Rags | 5.0 Mustangs | 13 | August 11th, 2007 11:47 PM |
| 5.0 Torque Specs | Twist 2 Go | 5.0 Mustangs | 1 | May 16th, 2006 12:52 AM |
